However, the progress of my project is that it is able to send the command to the robot to make it move, but upon receiving the data from ESP8266, I am not able to piece the data into a proper video streaming to view on the windows C# application. I have used C# bitmap library but not able work properly. Any help is much appreciated. Below is what I have done so far:
public async Task receiveData()
while(true)
ArraySegment<byte> buffer = new ArraySegment<byte>(new byte[819200]);
WebSocketReceiveResult result = await ws.ReceiveAsync(buffer, CancellationToken.None);
pbVideoFeed.Image = BytesToBitmap(buffer);
if (ws.State != WebSocketState.Open)
break;
private Bitmap BytesToBitmap(ArraySegment<byte> buffer)
MemoryStream stream = null;
byte[] image_data = new byte[409600];
Bitmap resize_img = new Bitmap(pbVideoFeed.Width, pbVideoFeed.Height);
Graphics graphic = Graphics.FromImage(resize_img);
image_data = buffer.ToArray();
try
stream = new MemoryStream(image_data);
Bitmap result = new Bitmap(stream);
graphic.InterpolationMode = InterpolationMode.High;
graphic.DrawImage(result, new Rectangle(0, 0, pbVideoFeed.Width, pbVideoFeed.Height));
graphic.Dispose();
return new Bitmap((Image)resize_img);
//return new Bitmap((Image)new Bitmap(stream));
catch (ArgumentException ex)
throw ex;
finally
stream.Close();
