I am pretty new here and this is my first post.
My Goal:
Send a PUSH notification to users on Android/iOS devices through ESP
Environment:
Arduino Sketch
Code Used:
https://github.com/beegee-tokyo/GCM-ESP8266/wiki - Thank you BeeGee for the code!
Well documented, so please have a look at the link. I did change few things which are reflected in the two files below
[list=]gcm_esp.ino
gcm_esp_test.ino[/list]
1. gcm_esp.ino
// Embedded System + GCM
#include <ArduinoJson.h>
#include <FS.h>
// /** Google API key */
const String API_key = "MyGCM_APIKey";
// Serial Output
#define DEBUG_OUT
/** Google Cloud Messaging server address */
char serverName[] = "http://android.googleapis.com";
/** Google Cloud Messaging host */
String hostName = "android.googleapis.com";
/** WiFiClient class to communicate with GCM server */
const int httpPort = 80;
WiFiClient gcmClient;
/** Reason of failure of received command */
String failReason = "unknown";
/** Array to hold the registered Android device IDs (max 5 devices, extend if needed)*/
#define MAX_DEVICE_NUM 1
String regAndroidIds[MAX_DEVICE_NUM];
/** Number of registered devices */
byte regDevNum = 1; // CHANGED TO TEST
writeRegIds
writes regAndroidIds[] to file gcm.txt as JSON object
returns true if successful, false if file error
boolean writeRegIds() {
Serial.println("1");
#ifdef DEBUG_OUT
Serial.println("===========================================");
Serial.println("writeRegIds");
#endif
// First check if the file system is mounted and working
FSInfo fs_info;
if (!SPIFFS.info(fs_info)) {
// Problem with the file system
#ifdef DEBUG_OUT
Serial.println("File system error");
#endif
failReason = "File system error";
return false;
// Open config file for writing.
File devicesFile = SPIFFS.open("/gcm.txt", "w");
Serial.println("Post Open for Write");
if (!devicesFile) {
#ifdef DEBUG_OUT
Serial.println("Failed to open gcm.txt for writing");
#endif
failReason = "Failed to open gcm.txt for writing";
return false;
// Create new device ids as JSON
DynamicJsonBuffer jsonBuffer;
// Prepare JSON object
JsonObject& regIdJSON = jsonBuffer.createObject();
Serial.println("Pre loop check for regDevNum");
// Add existing devices to JSON object (if any)
for (int i=0; i<regDevNum; i++) {
Serial.println("Test");
regAndroidIds[0] = "OneOfMyRegDeviceID"; // MANUALLY ENTERED THE DEVICE ID HERE REMOVING THE ORIGINAL LOOP TO TEST
regIdJSON[String(0)] = regAndroidIds[0];
Serial.println(regAndroidIds[0]);
//regAndroidIds[i]
// Convert JSON object to String
String jsonTxt;
regIdJSON.printTo(jsonTxt);
#ifdef DEBUG_OUT
Serial.println("New list of registered IDs: " + jsonTxt);
#endif
// Save status to file
devicesFile.println(jsonTxt);
devicesFile.close();
return true;
getRegisteredDevices
reads registered device IDs from file gcm.txt
saves found devices in global variable regAndroidIds[]
sets global variable regDevNum to number of devices found
returns true if successful, false if file error or JSON parse error occured
boolean getRegisteredDevices() {
Serial.println("2");
#ifdef DEBUG_OUT
Serial.println("getRegisteredDevices");
writeRegIds();
#endif
FSInfo fs_info;
#ifdef DEBUG_OUT
#endif
return false;
// Then get registered devices from the files
// open file for reading.
File devicesFile = SPIFFS.open("/gcm.txt", "r");
if (devicesFile) // Found file
// Read content from config file.
String content = devicesFile.readString();
// Convert file content into JSON object
JsonObject& regIdJSON = jsonBuffer.parseObject(content);
if (regIdJSON.success()) // Found some entries
regDevNum = 0;
for (int i=0; i<MAX_DEVICE_NUM; i++) {
if (regIdJSON.containsKey(String(i))) { // Found an entry
regAndroidIds[i] = regIdJSON[String(i)].asString();
regDevNum++;
#ifdef DEBUG_OUT
Serial.println("Found: " + regAndroidIds[i]);
#endif
#ifdef DEBUG_OUT
Serial.println("Found: " + String(regDevNum) + " devices");
#endif
return true;
} else { // File content is not a JSON string
#ifdef DEBUG_OUT
Serial.println("File content is not a JSON string");
#endif
failReason = "File content is not a JSON string";
return false;
} else { // File not found - not an error, just no registered IDs yet
regDevNum = 0;
#ifdef DEBUG_OUT
Serial.println("File does not exist");
#endif
failReason = "File does not exist";
return true;
addRegisteredDevice
adds a new device to the file gcm.txt
input String new device ID
returns true if successful, false if a file error occured or ID is invalid
boolean addRegisteredDevice(String newDeviceID) {
Serial.println("3");
Serial.println("TestBefore");
#ifdef DEBUG_OUT
Serial.println("addRegisteredDevice");
#endif
// Basic check if newDeviceID is valid
if (newDeviceID.length() != 140) {
#ifdef DEBUG_OUT
Serial.println("Invalid device id");
#endif
failReason = "Invalid device id";
return false;
// First get registered devices from the files
if (!getRegisteredDevices) {
#ifdef DEBUG_OUT
Serial.println("Error reading registered devices");
#endif
return false;
// Number of devices < MAX_DEVICE_NUM ???
if (regDevNum == MAX_DEVICE_NUM) {
#ifdef DEBUG_OUT
Serial.println("Maximum number of devices registered");
Serial.println("Delete another device before adding new one");
#endif
failReason = "Maximum number of devices registered";
return false;
// Check if id is already in the list
if (regAndroidIds[i] == newDeviceID) {
#ifdef DEBUG_OUT
Serial.println("Devices already registered");
#endif
failReason = "Devices already registered";
return false;
// Add new ID to regAndroidIds[]
regDevNum += 1;
regAndroidIds[regDevNum-1] = newDeviceID;
if (writeRegIds()) {
#ifdef DEBUG_OUT
Serial.println("Successful added id: " + newDeviceID);
#endif
// Refresh list with registered devices
getRegisteredDevices();
return true;
} else {
#ifdef DEBUG_OUT
Serial.println("Failed to added id: " + newDeviceID);
#endif
return false;
delRegisteredDevice
deletes all registration ida from the list
boolean delRegisteredDevice() {
Serial.println("4");
#ifdef DEBUG_OUT Serial.println("===========================================");
Serial.println("delRegisteredDevice");
#endif
#ifdef DEBUG_OUT
#endif
return false;
#ifdef DEBUG_OUT
Serial.println("Trying to delete all ids");
#endif
if (SPIFFS.remove("/gcm.txt")) {
#ifdef DEBUG_OUT
Serial.println("All registered device ids deleted");
#endif
regDevNum = 0;
return true;
} else {
#ifdef DEBUG_OUT
Serial.println("Error while deleting registration file");
#endif
failReason = "Error while deleting registration file";
return false;
return false;
delRegisteredDevice
deletes a registration id from the list
delRegId => registration id to be deleted. delAll must be false & delRegIndex must be 9999!!!!
returns true if successful, false if a file error occured or ID is invalid or not registered
boolean delRegisteredDevice(String delRegId) {
Serial.println("5");
int delRegIndex;
#endif
#ifdef DEBUG_OUT
#endif
return false;
#ifdef DEBUG_OUT
Serial.println("Trying to delete id: " + delRegId);
#endif
// Search for id entry
boolean foundIt = false;
if (regAndroidIds[i] == delRegId) {
foundIt = true;
delRegIndex = i;
break;
if (foundIt) {
// delete id entry
regAndroidIds[delRegIndex] = "";
for (int i=delRegIndex; i<regDevNum-1; i++) {
// Shift other ids
regAndroidIds[i] = regAndroidIds[i+1];
regDevNum -= 1;
if (!writeRegIds()) {
#ifdef DEBUG_OUT
Serial.println("Could not save registered ids");
#endif
return false;
} else {
#ifdef DEBUG_OUT
Serial.println("Successful deleted id: " + delRegId);
#endif
return true;
} else {
#ifdef DEBUG_OUT
Serial.println("Could not find registration id " + delRegId);
#endif
failReason = "Could not find registration id " + delRegId;
return false;
return false;
delRegisteredDevice
delRegIndex => index of id to be deleted
returns true if successful, false if a file error occured or index is invalid
boolean delRegisteredDevice(int delRegIndex) {
Serial.println("6");
#endif
#ifdef DEBUG_OUT
#endif
return false;
#ifdef DEBUG_OUT
Serial.println("Trying to delete id with index: " + String(delRegIndex));
#endif
// delete id entry
String delRegId = regAndroidIds[delRegIndex];
// Shift other ids
regDevNum -= 1;
#ifdef DEBUG_OUT
#endif
return false;
} else {
#ifdef DEBUG_OUT
#endif
return true;
return false;
gcmSendOut
sends message to https://android.googleapis.com/gcm/send to
request a push notification to registered Android devices
data - String with the Json object containing the reg IDs and data
returns true if successful, false if an error occured
boolean gcmSendOut(String data) {
Serial.println("7");
gcmClient.stop(); // Just to be sure
#ifdef DEBUG_OUT
Serial.println(serverName);
#endif
String resultJSON; // For later use
Serial.println("Pre connect server");
if (gcmClient.connect(serverName, httpPort)) {
Serial.println("Post connect server");
#ifdef DEBUG_OUT
Serial.println("Connected to GCM server");
#endif
String postStr = "POST /gcm/send HTTP/1.1\r\n";
postStr += "Host: " + hostName + "\r\n";
postStr += "Accept: */";
postStr += "*\r\n";
postStr += "Authorization: key=" + API_key + "\r\n"; // Here the application specific API key is inserted
postStr += "Content-Type: application/json\r\n";
postStr += "Content-Length: ";
postStr += String(data.length());
postStr += "\r\n\r\n";
postStr += data; // Here the Json object with the IDs and data is inserted
#ifdef DEBUG_OUT
Serial.print("This is the Request to ");
Serial.print(serverName);
Serial.println(" :");
Serial.println(postStr);
#endif
gcmClient.println(postStr); // Here we send the complete POST request to the GCM server
// Get response from GCM server
#ifdef DEBUG_OUT
Serial.println("Response from GCM server:");
#endif
String inString = "";
while (gcmClient.available())
char inChar = gcmClient.read();
inString += (char)inChar;
if (inString.indexOf("200 OK") >= 0) {
int startOfJSON = inString.indexOf("{\"multicast_id");
int endOfJSON = inString.indexOf("}]}");
resultJSON = inString.substring(startOfJSON,endOfJSON+3);
#ifdef DEBUG_OUT
Serial.println("Found JSON result: " + resultJSON);
#endif
failReason = "success";
} else {
#ifdef DEBUG_OUT
Serial.println("Didn't find 200 OK");
#endif
failReason = "Sending not successful";
gcmClient.stop();
} else {
#ifdef DEBUG_OUT
Serial.println("Connection to GCM server failed!");
#endif
failReason = "Connection to GCM server failed!";
if (failReason != "success") {
failReason = resultJSON;
return false;
} else {
return true;
gcmSendMsg
prepares the JSON object holding the registration IDs and data
calls gcmSendOut to forward the request to the GCM server
pushMessageIds - Json array with the keys (aka names) of the messages
pushMessages - Json array with the messages
a message can be any type of variable:
boolean, char, integer, long, float, string, ...
boolean gcmSendMsg(JsonArray& pushMessageIds, JsonArray& pushMessages) {
Serial.println("8");
#ifdef DEBUG_OUT
Serial.println("gcmSendMsg - JsonArrays");
#endif
// Update list of registered devices
if (regDevNum == 0) { // Any devices already registered?
#ifdef DEBUG_OUT
Serial.println("No registered devices");
#endif
failReason = "No registered devices";
return false;
if (pushMessageIds.size() != pushMessages.size()) {
#ifdef DEBUG_OUT
Serial.println("Different number of keys and messages");
#endif
failReason = "Different number of keys and messages";
return false;
int numData = pushMessageIds.size();
String data;
// Create JSON object with registration_ids and data
if (numData != 0) {
DynamicJsonBuffer jsonDataBuffer;
JsonObject& msgJSON = jsonBuffer.createObject();
// Add registration ids to JsonArray regIdArray in the JsonObject msgJSON
JsonArray& regIdArray = msgJSON.createNestedArray("registration_ids");
regIdArray.add(regAndroidIds[i]);
// Add message keys and messages to JsonObject dataArray
JsonObject& dataArray = jsonDataBuffer.createObject();
for (int i=0; i<numData; i++) {
String keyStr = pushMessageIds.get(i);
dataArray[keyStr] = pushMessages.get(i);
// Add JsonObject dataArray to JsonObject msgJSON
msgJSON["data"] = dataArray;
msgJSON.printTo(data);
} else { // No data to send
#ifdef DEBUG_OUT
Serial.println("No data to send");
#endif
failReason = "No data to send";
return false;
return gcmSendOut(data);
gcmSendMsg
pushMessages - Json object with the data for the push notification
boolean gcmSendMsg(JsonObject& pushMessages) {
Serial.println("9");
#ifdef DEBUG_OUT
Serial.println("gcmSendMsg - JsonObject");
#endif
#ifdef DEBUG_OUT
#endif
return false;
String data;
// Add JsonObject pushMessages to JsonObject msgJSON
msgJSON["data"] = pushMessages;
2. gcm_esp_test.ino
Google Cloud Messaging tutorial
part 2
-> web server for receiving registrations from Android devices
receive commands to maintain registration storage
receive command to request push notification
-> setup routine
=> main loop
To access the web server from outside your local LAN you need
to setup a url and prepare your router/modem to make this IP
accessible from the Internet
/* Includes from libraties */
//#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <Ticker.h>
// /** SSID of local WiFi network */
const char* ssid = "MySSID";
// /** Password for local WiFi network */
const char* password = "MySSIDPassword";
/* REMARK: I use fixed IP address for the ESP8266 module, not the DHCP function */
/** IP address of this module */
IPAddress ipAddr(xxx,xxx,x,x); // REPLACE WITH THE IP ADDRESS YOU WANT TO APPLY
/** Gateway address of WiFi access point */
IPAddress ipGateWay(xxx, xxx, x, x); // REPLACE WITH THE GATEWAY ADDRESS OF YOUR WIFI AP
/** Network mask of the local lan */
IPAddress ipSubNet(255, 255, 255, 0); // SHOULD WORK WITH MOST WIFI LANs
/** WiFiServer class to create simple web server */
WiFiServer server(80);
/** Timer for flashing blue communication LED */
Ticker comFlasher;
/** Timer for sending a push request to GCM every minute */
Ticker pushTrigger;
/** Flag for push request */
boolean doPush = false;
/** Blue LED on GPIO2 for communication activities (valid only for Adadfruit HUZZAH ESP8266 breakout) */
#define comLED 2
/** Just for testing, counter to be send as message */
int msgCnt = 0;
/* ===CODE_STARTS_HERE========================================== */
blueLedFlash
called by Ticker comFlasher
change status of led on each call
void blueLedFlash() {
int state = digitalRead(comLED);
digitalWrite(comLED, !state);
triggerGCM
called by Ticker pushTrigger
sets flag doPush to true for handling in loop()
will initiate a call to gcmSendMsg() from loop()
void triggerGCM() {
Serial.println("B");
doPush = true;
webServer
receives commands from web client or Android device
returns result as JSON string to the client
"result":"success" ==> command successful
"result":"timeout" ==> communication between client and server was interrupted
"result":"invalid" ==> unknown command or invalid Android ID
"result":"failed" ==> command unsuccessful because e.g. ID storage full, file error
Available commands:
-- Register a new id
<url>/?regid=<android registration id> with length 140 letter, no leading/trailing <">
-- List registered ids
<url>/?l
-- Delete all registered ids
<url>/?da
-- Delete specific registered id by 140 letter registration id
<url>/?di=<android registration id> with length 140 letter, no leading/trailing <">
-- Delete specific registered index
<url>/?dx=<index>
-- Send broadcast message to all registered devices
<url>/?s={"msgkeys":["key1","key2"],"msgs":["msg1","msg2"]}
Examples:
192.168.0.148/?l
returns
{"result":"success","0":"***ANDROID_REG_ID***","num":1}
192.168.0.148/?regid=APA91bHq3iaH0UqYadNegxi5lP0Li0lvumQvvKJS7GxtT9P0zkU-...-S6EOpbS
returns
192.168.0.148/?da
returns
{"result":"success"}
192.168.0.148/?s={"msgkeys":["message","timestamp"],"msgs":["Hello world","Christmas 2015"]}
sends {"message":"Hello world","timestamp":"Christmas 2015"} to all registered devices
returns {"result":"success","response":"{\"multicast_id\":6404311408057644811,\"success\":3,\"failure\":0,\"canonical_ids\":0,\"results\":[{\"message_id\":\"0:1453965670295623%adf4b72ff9fd7ecd\"},{\"message_id\":\"0:1453965670295621%adf4b72ff9fd7ecd\"},{\"message_id\":\"0:1453965670295907%cbe2ca3ff9fd7ecd\"}]}"}
void webServer(WiFiClient httpClient) {
Serial.println("C");
Serial.println("webServer");
#endif
comFlasher.attach(0.5, blueLedFlash);
String s = "HTTP/1.1 200 OK\r\nAccess-Control-Allow-Origin: *\r\nContent-Type: application/json\r\n\r\n";
int waitTimeOut = 0;
// Prepare json object for the response
JsonObject& root = jsonBuffer.createObject();
// Wait until the client sends some data
while (!httpClient.available()) {
delay(1);
waitTimeOut++;
if (waitTimeOut > 3000) { // If no response for 3 seconds return
#ifdef DEBUG_OUT
Serial.println("Timeout while waiting for data from client");
#endif
root["result"] = "timeout";
root["reason"] = "Timeout while waiting for data from client";
String jsonString;
root.printTo(jsonString);
s += jsonString;
httpClient.print(s);
httpClient.flush();
httpClient.stop();
comFlasher.detach();
digitalWrite(comLED, HIGH); // Turn off LED
return;
root["result"] = "success";
String req = httpClient.readStringUntil('\r');
#ifdef DEBUG_OUT
Serial.println("Received: "+req);
#endif
req = req.substring(req.indexOf("/"),req.length()-9);
Serial.println(req);
Serial.println("Nice");
#ifdef DEBUG_OUT
Serial.println("Trimmed command = "+req);
#endif
// Registration of new device
if (req.substring(0, 8) == "/?regid=") {
String regID = req.substring(8,req.length());
//Serial.println(regID);
#ifdef DEBUG_OUT Serial.println("RegID: "+regID);
Serial.println("Length: "+String(regID.length()));
#endif
// Check if length of ID is correct
if (regID.length() != 140) {
#ifdef DEBUG_OUT
Serial.println("Length of ID is wrong");
#endif
root["result"] = "invalid";
root["reason"] = "Length of ID is wrong";
} else {
// Try to save ID
if (!addRegisteredDevice(regID)) {
#ifdef DEBUG_OUT
Serial.println("Failed to save ID");
#endif
root["result"] = "failed";
root["reason"] = failReason;
} else {
#ifdef DEBUG_OUT
Serial.println("Successful saved ID");
#endif
root[String(i)] = regAndroidIds[i];
root["num"] = regDevNum;
// Send list of registered devices
} else if (req.substring(0, 3) == "/?l"){
if (getRegisteredDevices()) {
if (regDevNum != 0) { // Any devices already registered?
} else {
// Delete one or all registered device
} else if (req.substring(0, 3) == "/?d"){
String delReq = req.substring(3,4);
if (delReq == "a") { // Delete all registered devices
if (delRegisteredDevice(true)) {
} else {
} else if (delReq == "i") {
String delRegId = req.substring(5,146);
delRegId.trim();
if (delRegisteredDevice(delRegId)) {
} else {
} else if (delReq == "x") {
int delRegIndex = req.substring(5,req.length()).toInt();
if ((delRegIndex < 0) || (delRegIndex > MAX_DEVICE_NUM-1)) {
root["reason"] = "Index out of range";
} else {
if (delRegisteredDevice(delRegIndex)) {
} else {
// Send broadcast message to all registered devices
// Message must be a string in valid JSON format
// e.g. {"msgkeys":["key1","key2"],"msgs":["msg1","msg2"]}
} else if (req.substring(0, 3) == "/?s"){
String jsonMsgs = req.substring(4,req.length());
jsonMsgs.trim();
jsonMsgs.replace("%22","\""); // " might have been replaced with %22 by the browser
jsonMsgs.replace("%20"," "); // <space> might have been replaced with %22 by the browser
jsonMsgs.replace("%27","'"); // ' might have been replaced with %22 by the browser
#ifdef DEBUG_OUT
Serial.println("Received = " + jsonMsgs);
#endif
// Convert message into JSON object
JsonObject& regJSON = jsonBuffer.parseObject(jsonMsgs);
if (regJSON.success()) {// Found some entries
if (regJSON.containsKey("msgkeys")) {
if (regJSON.containsKey("msgs")) {
JsonArray& msgKeysJSON = regJSON["msgkeys"];
JsonArray& msgsJSON = regJSON["msgs"];
if (gcmSendMsg(msgKeysJSON, msgsJSON)) {
} else {
root["response"] = failReason;
} else {
root["reason"] = "JSON key msgs is missing";
} else {
root["reason"] = "JSON key msgkeys is missing";
} else {
root["reason"] = "Invalid JSON message";
} else {
root["reason"] = "Invalid command";
String jsonString;
s += jsonString;
httpClient.flush();
httpClient.stop();
setup
Initialize application
called once after reboot
Serial.println("D");
pinMode(comLED, OUTPUT); // Communication LED blue
#ifdef DEBUG_OUT
Serial.setDebugOutput(false);
Serial.println("");
Serial.println("====================");
Serial.println("ESP8266 GCM test");
#endif
WiFi.disconnect();
WiFi.mode(WIFI_STA);
WiFi.config(ipAddr, ipGateWay, ipSubNet);
WiFi.begin(ssid, password);
#ifdef DEBUG_OUT
Serial.print("Waiting for WiFi connection ");
#endif
int connectTimeout = 0;
#ifdef DEBUG_OUT
#endif
connectTimeout++;
if (connectTimeout > 60) { //Wait for 30 seconds (60 x 500 milliseconds) to reconnect
pinMode(16, OUTPUT); // Connected to RST pin
digitalWrite(16,LOW); // Initiate reset
ESP.reset();
#ifdef DEBUG_OUT
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
byte mac[6];
WiFi.macAddress(mac);
String localMac = String(mac[0], HEX) + ":";
localMac += String(mac[1], HEX) + ":";
localMac += String(mac[2], HEX) + ":";
localMac += String(mac[3], HEX) + ":";
localMac += String(mac[4], HEX) + ":";
localMac += String(mac[5], HEX);
Serial.print("MAC address: ");
Serial.println(localMac);
Serial.print("Sketch size: ");
Serial.print (ESP.getSketchSize());
Serial.print(" - Free size: ");
Serial.println(ESP.getFreeSketchSpace());
#endif
// Initialize file system.
if (!SPIFFS.begin())
#ifdef DEBUG_OUT
Serial.println("Failed to mount file system");
#endif
// Start the web server to serve incoming requests
server.begin();
// Start the timer to push a message every minute
pushTrigger.attach(60, triggerGCM);
// Send first push notification
// Create messages & keys as JSON arrays
DynamicJsonBuffer jsonBufferKeys;
DynamicJsonBuffer jsonBufferMsgs;
JsonArray& msgKeysJSON = jsonBufferKeys.createArray();
JsonArray& msgsJSON = jsonBufferMsgs.createArray();
char buf[4];
char msgOne[24] = "Test message number ";
itoa(msgCnt,buf,10);
strcat(msgOne,buf);
msgKeysJSON.add("message");
msgKeysJSON.add("timestamp");
msgsJSON.add(msgOne);
msgsJSON.add(buf);
gcmSendMsg(msgKeysJSON, msgsJSON);
msgCnt++;
loop
main program loop
wait for connection to web server
for testing purpose sends every minute a GCM notification to
// Handle new client request on HTTP server if available
if (client) {
webServer(client);
if (doPush) {
Serial.println("F");
doPush = false;
char buf[4];
strcat(msgOne,buf);
msgsJSON.add(buf);
msgCnt++;
Current Status:
It says connecting to android.googleapis.com but later goes in the else loop. Not sure why I cannot connect?
My serial output is as below:
Connecting to https://android.googleapis.com
Pre connect server
Can anyone please help? I think I am almost close to get everything working. Just need some help.
Thank you.
