Chat freely about anything...
By Bonzo
#93831 You could go with:
Multiple batteries in a easy change pack - one pack charging while the other is running. You could even measure the battery output and get your website to email you when it is close to dyeing. I did this on one of my setups without the emailing.
Batteries with a solar charger but will probably only last over the summer unless you live somewhere sunny
A big battery :)
If you use deep sleep and only send data data every now and again that will make the battery last a lot longer.
If you get to enthusiastic things get complicated quickly. I had two battery packs with an auto switch over IC and I would take out the flat pack and replace it. It also had a solar panel!
