Not found with search function.
Hard coded and not possible ?
(Not found schematics for ESP-01 device)
With C directly , AT firmware or LUA firmware if possible
Thanks
Explore... Chat... Share...
martinayotte wrote:The RED Led is connected to Power, while the BLUE Led is connected to TX.
So, you can not control those leds. You still can use some other GPIOs...
int pin = 1; //GPIO1
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_GPIO1); //use pin as GPIO1 instead of UART TXD
gpio_output_set(0, 0, 1 << pin, 0); // enable pin as output
gpio_output_set(1 << pin, 0, 0, 0); // set pin high
gpio_output_set(0, 1 << pin, 0, 0); // set pin low
