By Michael Bilenko
#12664 Hello Everyone!
I'm interested in maximum attainable speed of data transmission for esp to smartphone.
Now i'm using AT command mode, baud rate 921600, softap mode on esp.
ESP running tcp server in multiple connection mode.
using AT+CIPSEND=1024(or AT+CIPSEND=2048) for data transmission. Transmission of 2MB file takes about 5 minutes. Is there any tricks to speedup transmission? Maybe using unvarnished mode?
Thanks
By Michael Bilenko
#12717 Here is my PC python code, for reference
Code: Select allimport struct
import time
import serial
import re
import pdb
import base64
import os,sys,traceback
class EspSerial:
    def __init__(self):
        if os.name == 'posix':
            portname='/dev/tty.usbserial'
        else:
            portname = 'COM16'
        self.ser = serial.Serial(port=portname, baudrate=921600, timeout=1.0)
        self.exit = False
        self.current_cmd = ""
        self.echo_suppressed = False
        self.result_string = ""
        self.result = False
        self.recv_buffer = ""
        self.binary_mode = False
        self.expected_bytes = 0
        self.current_conn = -1
    def process_line(self,line):
        if line != "":
            print "                       >> GOT", line
        if not self.echo_suppressed:
            if line == self.current_cmd:
                print "Found echo"
                self.echo_suppressed = True
                return
        if line == "":
            return
            #print "Empty line.. passing..."
        if line == "OK":
            self.exit = True
            self.result = True
            return
        if line == "no change":
            self.exit = True
            self.result = True
            return
        if line == "ERROR":
            self.exit = True
            self.result = False
            return
        self.result_string = line
    def handle_line(self,line):
            expr = "\+IPD,([0-9]+),([0-9]+):"
            groups = re.match(expr,line)
            if groups:
                print "Found IPD"
                v = groups.groups()
                self.current_conn = int(v[0])
                self.expected_bytes = int(v[1])
                #print port,self.expected_bytes
                line = re.sub(expr,"",line)
                self.binary_mode = True
            if self.binary_mode:
                print "Found binary mode string: ",line
                self.expected_bytes -= len(line)
                self.recv_buffer += line
                if self.expected_bytes <= 0:
                    self.poll_string("OK",2.0)
                    self.packet_received(self.current_conn)
                return ""
            else:
                line = line.replace("\n","")
                line = line.replace("\r","")
                return line
    def poll_string(self,string,timeout):
        self.exit = False
        self.result = False
        start = time.clock()
        while True:
            line = self.ser.readline()
            line = self.handle_line(line)
            self.process_line(line)
            if line == string:
                return
            if (time.clock() - start) > timeout:
                self.exit = True
                raise Exception('Timeout', ':(')
    def poll_answer(self,timeout):
        self.exit = False
        self.result = False
        while not self.exit:
                self.exit = True
    def send_cmd_ok(self, cmd,timeout=5.0):
        self.current_cmd = cmd
        self.ser.flush()
        self.ser.write(cmd+"\n")
        self.ser.flush()
        self.poll_answer(timeout)
            raise Exception('No echo', ':(')
        #time.sleep(0.5)
        return self.result
    def send_cmd_string(self, cmd, timeout=5.0):
        self.ser.flush()
        self.ser.write(cmd+"\r\n")
        self.ser.flush()
        return self.result_string
    def send_cmd_wait_string(self, cmd, string, timeout=5.0):
            self.ser.flush()
            self.ser.flush()
            self.poll_string(string,timeout)
#            if not self.echo_suppressed:
#                raise Exception('No echo', ':(')
            return True
    def send_pkt(self,conn,packet):
        #packet = base64.b64encode(packet)
        self.ser.flushInput()
        cmd = "AT+CIPSEND="+str(conn)+','+str(len(packet))+"\r\n"
        print "                   >> SENDING", cmd
        self.ser.write(cmd)
        self.ser.flush()
        self.poll_string("AT+CIPSEND="+str(conn)+','+str(len(packet)),2.0)
        self.ser.read();self.ser.read();
        self.ser.write(packet)
        #print "Ref ",packet
        #print "Echo",\
        self.ser.read(len(packet))
        self.poll_string("SEND OK",10.0)
        print "Send finished"
    def send_pkt_nomux(self,conn,packet):
        cmd = "AT+CIPSEND"
        self.ser.write(cmd)
        self.ser.flush()
        self.poll_string("AT+CIPSEND",2.0)
        #print "Echo",\
        self.ser.write("+++\n\r")
    def packet_received(self,conn):
        packet = self.recv_buffer
        print "Receive callback", packet
        data = gen_coord()
        print len(data)
        self.send_pkt(conn,"LEN:%d\n" % len(data))
        #self.send_pkt(conn,gen_coord())
        for i in range(0,2500):
            print i
            self.send_pkt(conn,base64.b64encode(gen_coord())+"\n")
def gen_coord():
    s = ""
    startx = 43.0
    starty = 22.0
    for i in range(0,50):
        startx += 0.00002
        starty += 0.00002
        s += struct.pack("dd", startx, starty)
    print len(s)
    return s
gen_coord()
s = EspSerial()
print "Removing echo"
s.send_cmd_ok("ATE0")
print "Resetting ..."
s.send_cmd_wait_string("AT+RST", "ready",10.0)
print "Query version ..."
firmver = s.send_cmd_string("AT+GMR")
print "Firmware version ", firmver
print "Turninng into AP mode...."
s.send_cmd_ok("AT+CWMODE=3",10.0)
print "Setting credentials...."
s.send_cmd_ok("AT+CWSAP=\"test\",\"testtest\",11,0",10.0)
print "MUX setting...."
s.send_cmd_ok("AT+CIPMUX=0",10.0)
s.send_cmd_ok("AT+CIPMODE=1",10.0)
print "Starting client"
time.sleep(20.0)
s.send_cmd_ok("AT+CIPSTART=\"TCP\",\"192.168.4.100\",6000")
s.send_pkt_nomux(0,base64.b64encode(gen_coord())+"\n")
while True:
    try:
        s.poll_answer(5.0)
    except:
        print "Unexpected error:", sys.exc_info()[0]
        print traceback.print_exc(file=sys.stdout)
