-- PCF8574
-- P7 P6 P5 P4 P3 P2 P1 P0
-- D7 D6 D5 D4 (BL) EN RW RS
-- HD44780
id = 0x00
sda = 3 -- GPIO2
scl = 4 -- GPIO14
dev = 0x23 -- PCF8574
reg = 0x4e -- write
var1 = 0x04
i2c.setup(id, sda, scl, i2c.SLOW)
function send(data)
local bl = 0x08 -- 0x08 = back light on
local ls = 0x01
local value = {}
-- print (#data)
for i = 1, #data do
table.insert(value , data[i] + bl + var1 + rs)
-- print (value , data[i], rs)
table.insert(value , data[i] + bl + rs) -- fall edge to write
-- print (value , data[i] , rs)
i2c.start(id)
i2c.address(id, dev ,i2c.TRANSMITTER)
i2c.write(id,value)
-- print (value)
i2c.stop(id)
-- init
rs = 0x00
send({0x30})
tmr.delay(4100)
send({0x30})
tmr.delay(100)
send({0x30})
send({0x20, 0x20, 0x80}) -- 4 bit, 2 line
send({0x00, 0x10}) -- display clear
send({0x00, 0xf0}) -- display on
print ( " Finish the setup")
nibble = {
["0"] = 0x00,
["1"] = 0x10,
["2"] = 0x20,
["3"] = 0x30,
["4"] = 0x40,
["5"] = 0x50,
["6"] = 0x60,
["7"] = 0x70,
["8"] = 0x80,
["9"] = 0x90,
["a"] = 0xa0,
["b"] = 0xb0,
["c"] = 0xc0,
["d"] = 0xd0,
["e"] = 0xe0,
["f"] = 0xf0
str = "Hello world!!!! Hello world!!!!"
for i = 1, #str do
if i~=17 then
rs = 0x01
local char = string.byte(string.sub(str, i, i))
send({
nibble[string.sub(string.format("%x", char), 1, -2)],
nibble[string.sub(string.format("%x", char), 2)]})
rs = 0x00
send({0xC0,0x00}) -- new line
rs = 0x01
send({
Question : what is the voltage applied to lcd i2c ? I tried3.3v and characters look very dull, the lcd needs 5v but the issue is esp gpios are not 5v tolerant as they are connected by SCL, SDA l2c pins from led and they are carrying 5 volts
Let me know thanks.
I had the same issue. The LCD must be power up with 5V. To connect to the I2C bus of the ESP8266 I've used level shifters.
With the level shifters it works fine, and you can have a 3.3V I2C bus and a 5V I2C bus.
