By alonewolfx2
#6581
Baoshi wrote:That's a good hint. My router's lease time is 24 hours, and I can confirm the module re-lease ip address every 5 minutes *sharp*. Would it be the ESP internal timer problem?
i think same thing. maybe Athena can deal with it
By Athena
#6657
Baoshi wrote:
Athena wrote:@Baoshi ,could you show me some error logs ? And your account of Espressif BBS has been actived ;)
Many thanks Athena.
The following is the dump from UART0. I also attach my testing code, basically same as the rtos sdk sample without the client part.
Code: Select all[00]
 ets Jan  8 2013,rst cause:1, boot mode:(3,7)
load 0x40100000, len 28956, room 16
tail 12
chksum 0x8b
ho 0 tail 12 room 4
load 0x3ffe8000, len 1968, room 12
tail 4
chksum 0x05
load 0x3ffe87b0, len 6716, room 4
tail 8
chksum 0xc2
csum 0xc2
pp_task_hdl : 3fff1c68, prio:20, stack:512
ApiMsgMutex created
idle_task_hdl : 3fff42a8
tim_task_hdl : 3fff4500
xPortStartScheduler
OS SDK ver: 0.0.5 compiled @ Jan  4 2015 13:52:04
phy ver: 273, pp ver: 6
SDK version:0.0.5
mode : sta(18:fe:34:9c:d2:ba)
add if0
S > create socket: 0
S > bind port: 80
S > listen ok
S > wait client
scandone
add 0
aid 4
aid end
cnt
connected with OOOO, channel 1
dhcp client start...
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
rm match
reconnect
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
-----------------------------< 5 minutes later
rm match
reconnect
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
rm match
reconnect
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
rm match
reconnect
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
rm match
reconnect
b    << strange 'b' here
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
rm match
reconnect
scandone
add 0
aid 4
aid end
cnt
ip:192.168.0.157
mask:255.255.255.0
gw:192.168.0.1
@Baoshi , it seems that your disconnection to router is because that you do nothing since connected to router...
Please try to ping ESP8266 from PC, and see if it still disconnect from router.. PC -> Router -> ESP8266 , try ping
