It didnt matter which way round I set the thing up either as a client of my router or as an access point directly I found the TCP connection
would simply drop out for no reason. I played with several FW Versions up to 9.3 which all seamed to have the problem except
00170901 which didnt have the issue as far as I could tell.
I cant believe its not an acknowledged problem, this is the first thing you do, try out the AT commands to set up a connection
then start sending lines of text, and then bang.
Can anyone state for a fact there is NO problem and its something Im doing wrong.
There is a lot of chat here about developing for the ESP8266 directly but for my first use I just want to add it to an existing project
using the serial interface to send data, which I would have thought would be most peoples first steps.
I dont want a web server or anything complex just to be able to open a socket and get data, dont mind which end is doing the
listening or is the AP, I just want a stable connection.
may try the 9.5 beta if you think its fixed
... Simon
