By MarekB
#6078 I think the EX chips are pretty common now (I have a few ordered at different times and they are all EX ones).
If you can't find a better way to figure out how to make the 201 work, I would try to power on both and measure voltage on each pin of both chips (prepare a steady hand). The voltages might not necessarily need to be the same on both boards in order to make it work but it might give you some hints (or not).
By elac
#6182 To flash the 201 you must pull IO15 and IO0 low. CHP_EN is tied to 3.3V as usual.
To communicate after flashing keep IO15 pulled low.
I upgraded to ai-thinker V0.9.5 that's been modded with GPIO and ADC commands, works great.
By MartynC
#6303 Thanks for the help. Turns out I had a faulty breadboard!
Have the device booting. Baud rate pre set at 115200.
Have not tried to flash a firmware yet though.
Comes up as:
¹û ÔÆ ¿Æ ¼¼
³Ð½Ó¸÷Ààµç×ÓÏîÄ¿¿ª·¢
http://goouuu.com
ready
AT
OK
AT+GMR
0019000902
OK
I assume the garbage is Chinese. I am using the Arduino serial monitor which I believe cannot display the characters correctly.
I had thought the mini antenna would have increased the signal strength but it does not appear to be any better than the 01 module.
