By perseauk
#7394 UPDATE
I finally got it working! I can send AT commands and I get responses every time. Basically all I had to do was connect an external power supply and use a USB->serial converter and it ended up working with no problems. Thank you all for your help, I really appreciate it.
By blabla9879
#8740
perseauk wrote:UPDATE
Hi Byperseauk,
I think I'm in the same boat as you at the start of this thread. I got two ESP8266 ES-03s in the mail and after soldering connections to both of them and following online threads, I am STILL not having any luck flashing them :\ The flasher programs I am using are unable to detect or communicate with the ESP8266s. I'm thinking it might be my pinouts, what were yours exactly?
I have:
VCC, CH_PD -> 3.3v power supply
GPIO0 , GPIO14, GND-> GND
TX -> RX of serial converter
RX -> TX of serial converter (I have a 5v FTDI USB to Serial and had to use a resistor divider to level shift to 3.3v)
If those are pin outs are correct, then maybe the super cheap FTDI I bought on ebay may be the issue -__-
Thanks in advance for your help!
By MeNoGeek
#8784
blabla9879 wrote:VCC, CH_PD -> 3.3v power supply
GPIO15 to Gnd, not GPIO14! And better use a 1 to 10k resistor between CH_PD and Vcc.
By blabla9879
#9007
Hi MeNoGeek,
Yes, many of the threads I've looked at including on here have been suggesting GPIO15 to GND (http://tech.scargill.net/christmas-post-in-wark/). I still have not had any luck so far and I am beginning to suspect the cheap FTDI breakout I bought may not be doing the job..
I've ordered a new FTDI breakout but this time with a CH430 on it. I'll post soon with an update once I get my hands on it.
