By gggggggg
#66064
gggggggg wrote:Alternatively this:
https://www.ebay.com.au/p/?iid=27224880 ... s&&&chn=ps
Might have a better way to get different status.
In theory, sound ok?
Though the ESP only has 1 analog in, so I could not read the different states. Though inside something might be giving off different voltages..
By rudy
#66067 The first link looks to be just an indicator, if it is going off. The second one is like the circuit I showed. Pretty expensive for both of them. I'll see what else I can dig up.
By rudy
#66105 A 12 hour day at work and you figure during that time I would have an opportunity to look up the information on our fencer indicator design. But it was a busy day and I couldn't. I wanted to get some details but I will just briefly mention it now. We needed to add an indicator to show the fence condition. I don't really want to call it a voltage indicator as the range might not have been linear. But it did show different loading so it did what it needed to.
We added a wire through one of the output transformer's lamination holes. Not in with the high voltage wire's window area, but through the holes in the E portion.
It was away from any high voltage. We used one turn through that hole and got enough signal that we could send through a diode and into a capacitor. The voltage on the capacitor was measured by a bar graph display chip. It was quite effective.
I'l try and get more details but it would be on Tuesday if I can remember. (Long Weekend here :D )
By hani
#84335 Hey,
could you gain some long term experience with your circuitry and like to share it here?
Maybe you could explain a little more exact how you designed the voltage Transformer ?
So far i could only figure out this project here (https://github.com/kiu/lofence/) which uses a non isolated Resistor Voltage Divider to set the voltage down and thus depends on the battery power for isolation. With an ESP8266 i would have used a AC Mains Power supply - thus the detection should really be isolated
Best Wishes from Germany,
Markus
