Sirquil wrote:Good Mornnig,
Created a sketch that creates variables: "effects," "intensity," and "color pallete" for use with WLED. More details about the WLED can be found at: WLED Project
Sketch runs on ESP32 or ESP8266.
OpenAI's, ChatGPT assisted on the project.
Results of MPU6050 Accelerometer and Gyro Breakout project
Project results
Github repository of MPU6050_WLED project
Short video of WLED running
Shows WLED Strip of RGB leds lighting effects, intensity, and color palette.
Plan is to use "paddle/wand" to create changing RGB lighting effects, intensity, and color palette of WLED Controller output. Should work with any WLED Controller as only uses HTTP api. "Paddle/wand" has been named "Chromawand."
Regards,
William
It's exciting to see the development of this project using WLED and the incorporation of the MPU6050 accelerometer and gyro breakout. The addition of the "Chromawand" as a way to control the RGB lighting effects, intensity, and color palette is a creative solution. It's impressive that the project uses HTTP API, making it compatible with any WLED Controller. The short video provides a great visual demonstration of the project in action. Well done to the project team and ChatGPT for their contributions.
Fm whatsapp
