By MeNoGeek
#15897
extraclassik wrote:which one is ok ?
I guess the esp-12 is the most popular, so you'll find more information on this one:
http://www.aliexpress.com/store/product ... 63708.html
and
http://www.aliexpress.com/item/Trustmar ... 25280.html
Or you could buy this:
http://www.aliexpress.com/item/Note-tha ... 06593.html
Just power it with your ATX PS, and wire the relay boards.
You might have to desolder and remove the LEDs (or cut their traces) so they don't eat power from the relay board.
http://www.aliexpress.com/item/Single-chip-4-channel-relay-expansion-Board-supported-the-AVR-51-PIC-4-channel-relay-module/821672110.html
That might work, but you'd better ask the seller if it can be operated with a 3.3V microcontroller instead of a 5V one.
EDIT: You will also need a USB to UART converter, so in case you don't already have one, this is the model I use:
http://www.ebay.co.uk/itm/360912068999
By MeNoGeek
#15919 I like that cheap board, and thanks to MacDog, a schematic and a layout picture are now available:
viewtopic.php?p=15603#p15603
And I also like the idea of controlling an ATX PS. I just have to find what I'd need to switch on when I'm not home :/ What will you use it for?
