GPIO2 is pin 2 in the code for sure I'm using it now for a DHT sensor on one
Explore... Chat... Share...
#include <SPI.h> // Required to use BMP180
#include <DHT.h>
#include <stdio.h>
#define DHT_PIN 2 //DHT dht;//DHT22 for my sensorRHT03-others in library
DHT dht(DHT_PIN,DHT22,15);
#define TIMEOUT 3000 //3 second timout
#define SPARKFUN_UPDATE_TIME 60000 //Update SparkFun data server every 60000 ms (1 minute).
unsigned long timer1 = 0;
unsigned long timer2 = 0;
char server[] = "data.sparkfun.com"; // name address for data.sparkFun (using DNS)
// Set the static IP address to use if the DHCP fails to assign
const String publicKey = "RMzp9ANyqzfjw4drzNnZ";
const String privateKey = "-------------Your key----------------";
const byte NUM_FIELDS = 4;
const String fieldNames[NUM_FIELDS] = {"humidity" , "pressure2" , "temp" , "temp2"};
String fieldData[NUM_FIELDS];
//Character array to hold results
char results[4];
//const int requestInterval = 20000;
long lastAttemptTime = 0;
float humidity=0;
float temp=0;
long pressure2 = 0;
float temp2;
// pins used for the connection with the sensor
// the others you need are controlled by the SPI library):
const int dataReadyPin = 3; //Gotta check these BMP180
const int chipSelectPin = 4;//Gotta check these BMP180
double T,P,p0,a;
//float temp2 = 0.0;
long lastReadingTime = 0;
#include <SFE_BMP180.h>
#include <Wire.h>
// You will need to create an SFE_BMP180 object, here called "pressure":
WiFiClient client;
SFE_BMP180 pressure;
#define ALTITUDE 750.0 // Altitude of My HQ in meters
void setup()
{ Serial.begin(115200);
const char* ssid = "ME-HOME";
const char* password = "";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
delay(10);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.println("all going");
// Initialize the sensor (it is important to get calibration values stored on the device).
if (pressure.begin())
Serial.println("BMP180 init success");
// Oops, something went wrong, this is usually a connection problem,
// see the comments at the top of this sketch for the proper connections.
Serial.println("BMP180 init fail\n\n");
//while(1); // Pause forever.Action blocked as mine not working atm
//Setup pressure and temp2
//Sensor's memory register addresses:
const int PRESSURE = 0x1F; //3 most significant bits of pressure
const int PRESSURE_LSB = 0x20; //16 least significant bits of pressure
const int TEMPERATURE = 0x21; //16 bit temperature reading
//Configure SCP1000 for low noise configuration:
writeRegister(0x02, 0x2D);
writeRegister(0x01, 0x03);
writeRegister(0x03, 0x02);
// give the sensor and Ethernet shield time to set up:
delay(1000);
//Set the sensor to high resolution mode tp start readings:
writeRegister(0x03, 0x0A);
void loop()
char status; // Loop here getting pressure readings every 10 seconds.
status = pressure.startTemperature();
if (status != 0)
// Wait for the measurement to complete:
delay(status);
// Retrieve the completed temperature measurement:
// Note that the measurement is stored in the variable T.
// Function returns 1 if successful, 0 if failure.
status = pressure.getTemperature(T);
if (status != 0)
status = pressure.startPressure(3);
if (status != 0)
delay(status);
// Retrieve the completed pressure measurement:
// Note that the measurement is stored in the variable P.
// Note also that the function requires the previous temperature measurement (T).
// (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
status = pressure.getPressure(P,T);
if (status != 0)
// Print out the measurement:
// Serial.print("absolute pressure: ");
//Serial.print(P,2);
fieldData[1]=String(P,2);
fieldData[3]=String(T,2);
else Serial.println("error retrieving BMP pressure measurement\n");
else Serial.println("error starting BMP pressure measurement\n");
else Serial.println("error retrieving BMP temperature measurement\n");
else Serial.println("error starting BMP temperature measurement\n");
delay(25000); // Pause for 5 seconds
//Update sparkfun data server every 60 seconds.
// Convert each value to a string for our request to App Engine
delay(200);
humidity = dht.readHumidity();
temp = dht.readTemperature(); //temp = (temp*9/5) + 32 - 1; //To Farenheight calibrate here
String temp_string = dtostrf(temp*100, 4, 0, results);
String humidity_string = dtostrf(humidity*100, 4, 0, results);
delay(200);
fieldData[0]=String(humidity);
fieldData[2]=String(temp);
//get pressure and temp2
if (millis() - lastReadingTime > 1000){
// if there's a reading ready, read it:
// don't do anything until the data ready pin is high:
if (digitalRead(dataReadyPin) == HIGH) {
getData();
// timestamp the last time you got a reading:
lastReadingTime = millis();
delay(200);
if(millis() > timer1 + SPARKFUN_UPDATE_TIME)
timer1 = millis(); //Update timer1 with the current time in miliseconds since startup.
Serial.println("Posting by timer !");
postData(); //Send data to sparkfun data server.
Serial.println("Just after timer1\n");
Serial.println(fieldData[0] );
Serial.println(fieldData[1] );
Serial.println(fieldData[2] );
Serial.println(fieldData[3] );
void postData()
// Make a TCP connection to remote host
if (client.connect(server, 80))
// Post the data! Request should look a little something like:
// GET /input/publicKey?private_key=privateKey&light=1024&switch=0&name=Jim HTTP/1.1\n
// Host: data.sparkfun.com\n
// Connection: close\n
// \n
client.print("GET /input/");
client.print(publicKey);
client.print("?private_key=");
client.print(privateKey);
for (int i=0; i<NUM_FIELDS; i++)
client.print("&");
client.print(fieldNames[i]);
client.print("=");
client.print(fieldData[i]);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println();
//Serial.println( fieldNames[],fieldData[]);
Serial.println(F("Connection failed"));
while (client.connected())
if ( client.available() )
char c = client.read();
Serial.print(c);
client.stop();
[code]
void getData() {
Serial.println("Getting reading");
//Read the temperature data
int tempData = readRegister(0x21, 2);
// convert the temperature to celsius and display it:
temp2 = (float)tempData / 20.0;
//Read the pressure data highest 3 bits:
byte pressureDataHigh = readRegister(0x1F, 1);
pressureDataHigh &= 0b00000111; //you only needs bits 2 to 0
//Read the pressure data lower 16 bits:
unsigned int pressureDataLow = readRegister(0x20, 2);
//combine the two parts into one 19-bit number:
pressure2 = ((pressureDataHigh << 16) | pressureDataLow)/4;
Serial.print("Temperature: ");
Serial.print(temp2);
Serial.println(" degrees C");
Serial.print("Pressure: " + String(pressure2));
Serial.println(" Pa");
//Send a write command to SCP1000
void writeRegister(byte registerName, byte registerValue) {
// SCP1000 expects the register name in the upper 6 bits
// of the byte:
registerName <<= 2;
// command (read or write) goes in the lower two bits:
registerName |= 0b00000010; //Write command
// take the chip select low to select the device:
digitalWrite(chipSelectPin, LOW);
SPI.transfer(registerName); //Send register location
SPI.transfer(registerValue); //Send value to record into register
// take the chip select high to de-select:
digitalWrite(chipSelectPin, HIGH);
//Read register from the SCP1000:
unsigned int readRegister(byte registerName, int numBytes) {
byte inByte = 0; // incoming from the SPI read
unsigned int result = 0; // result to return
// of the byte:
registerName <<= 2;
registerName &= 0b11111100; //Read command
// send the device the register you want to read:
int command = SPI.transfer(registerName);
// send a value of 0 to read the first byte returned:
inByte = SPI.transfer(0x00);
result = inByte;
// if there's more than one byte returned,
// shift the first byte then get the second byte:
if (numBytes > 1){
result = inByte << 8;
result = result |inByte;
// return the result:
return(result);
