By Jabberwock
#17985 I think the pull-up might be the problem - the module stops responding at restart even if I just connect a wire to it (without connecting it to the relay input). The input must also be pulling it down. On the other hand, the module stops working even if I connect it to the input without restarting.
I also have used a level converter (3.3V ---> 5V) between the GPIO and the input of the relay, but it makes no difference.
By j0hncc
#17987
Jabberwock wrote:I think the pull-up might be the problem - the module stops responding at restart even if I just connect a wire to it (without connecting it to the relay input). The input must also be pulling it down. On the other hand, the module stops working even if I connect it to the input without restarting.
If you can locate a schematic of the relay module you should be able to confirm that that's the problem...
By GeorgeIoak
#18015 You can't tell from the picture but I'll assume that there is some sort of transistor on that relay board. The relay you show is a 5V relay and the ESP modules operate at 3.3V so you need a 3.3V relay.
If you have a link to the module you are trying to use we can confirm and recommend the best method to get this to work for you.
