I forgot to mention I did put a 2 uF capacitor Vcc to ground at the chip. The tx and rx wires are very short. I was only able to connect to the esp chip at one baud rate. Interestingly, it was 230400 (and only 230400) at one time (and one flasher), but then changed to 115200 and only 115200. As I did a lot of tries, now cannot remember if it was the same or the other of the 2 chips I have, and also if it was specific to the flasher I used. Anyhow, I will follow the spirit of you suggestion and make sure the power it sable and clean, and noise is minimized.
Thank again
