By bencom
#27070
lethe wrote:The ESP has another UART TX. Afaik the solution recommended by espressif is to use that port if you need a clean serial output.
Search for uart swap in the API docs.
Ah... Got it. Thank you very much. This sounds like the right solution. I was thinking swap only swaps the uart to the same pins but it appears swapping also changes the pins one uses. Should have read the docs for the swap function.
Once again thanks for the help... Much appreciated.
Sorry for barking up the wrong tree.
By occam
#28554
lalo_uy wrote:On boot the ESP send a boot message at 76800 bps.
May be this is the garbage you notice.
Setting a terminal emulator (Realterm) to 76800 still results in garbage
