Just to clarify this a compiler. The project I am working on is an interpreter.
http://esp8266basic.com
A BASIC interpreter for your ESP
Working now on Autodrop3d. A 3d printer with automatic part ejection system. https://autodrop3d.com
Explore... Chat... Share...
pvvx wrote:How to find out the available disk space to save the maximum file?I am not sure what you are asking. Can you explain in more detail what you are wanting to know?
pvvx wrote:ZBasic built-in programmer not check types of Flash on modules ESP8266?That is correct. The default is 512KB of Flash. If you have a 2MB Flash you can use the compiler directive shown below near the beginning of the main .bas file as described in the manual.
Option DeviceParameter FlashSize "2M"
dkinzer wrote:pvvx wrote:How to find out the available disk space to save the maximum file?I am not sure what you are asking. Can you explain in more detail what you are wanting to know?
dkinzer wrote:pvvx wrote:ZBasic built-in programmer not check types of Flash on modules ESP8266?That is correct. The default is 512KB of Flash. If you have a 2MB Flash you can use the compiler directive shown below near the beginning of the main .bas file as described in the manual.Code: Select allOption FlashSize "2M"
pvvx wrote:How to find out the available disk space to save the maximum file?There is no ZBasic System Library routine to get the SPIFFS free space. That is a good thing to add.
pvvx wrote:SPIFFS = gruesome file systemIf you have a better one, you can add it to your ZBasic app and use it in place of SPIFFS. You would need to define your own interface to it but you can make external functions available to ZBasic by importing the definitions. This advanced topic is discussed in section 6.8 of the ZBasic Language Reference.
pvvx wrote:Which option for W25Q128FV Flash?I misstated the option to specify the Flash size, it is actually "Option DeviceParameter FlashSize" and for the Flash chip you referred to it would be
Option DeviceParameter FlashSize "16M"
