good luck ......
good luck ......
Explore... Chat... Share...
xtal wrote:If you are using the FT232RL usb adapter, I would highly suspect it. I had 10 of the units, only 2 out of the 10 would load flash reliably. I switched to a prolific style [ that was crystal controlled] no more issues, The Ft232 appears to have problems with long transfers, short transfers worked fine.
good luck ......
Agentsmithers wrote:Can you send over a link and Ill order one today and try it out.
Agentsmithers wrote:xtal wrote:If you are using the FT232RL usb adapter, I would highly suspect it. I had 10 of the units, only 2 out of the 10 would load flash reliably. I switched to a prolific style [ that was crystal controlled] no more issues, The Ft232 appears to have problems with long transfers, short transfers worked fine.
good luck ......
