http://www.ulrichradig.de/home/index.ph ... t-net-node
Explore... Chat... Share...
folny82 wrote:I'd still like to try adding DMX output GPIO2 and combine it with ArtNet library you can look at the code if it would be possible ?.
sfranzyshen wrote:folny82 wrote:I'd still like to try adding DMX output GPIO2 and combine it with ArtNet library you can look at the code if it would be possible ?.
So ... you want ws2812 on gpio 0 and a seperate dmx out on gpio 2 ...
does this mean a gateway artnet<->dmx ?
for artnet & tpm2net support I refer frans-willem EspLightNode ... I have git clone verison (with new changes here)
https://github.com/sfranzyshen/EspLightNode
