The sense loop that I described above was only used as a low power signal for the monitoring circuit. A wire routed through one of the corner holes in the transformer gave us enough signal. The output of the transformer is a short duration pulse. The wire through the transformer was a single turn secondary winding. Because the output of the transformer is a pulse, and not a symmetrical output, only one end of the sense loop can be connected to the rectifier. If the other wire were used, there would be little output voltage to rectify and filter.
