Passed through 436746 cycles.
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 237028 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26729 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1500 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1036 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 29728 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 266293 bytes (27%) of program storage space. Maximum is 958448 bytes.
Global variables use 32264 bytes (39%) of dynamic memory, leaving 49656 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM3
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 5c:cf:7f:b9:df:e8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Traceback (most recent call last):
File "Q:\portable\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3582, in main
esp.change_baud(args.baud)
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 113, in inner
return func(*args, **kwargs)
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 795, in change_baud
self.command(self.ESP_CHANGE_BAUDRATE, struct.pack('<II', baud, second_arg))
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 386, in command
p = self.read()
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 331, in read
return next(self._slip_reader)
File "Q:/portable/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
w/ GUI Admin Client, Drag & Drop File Manager, OTA Built-In, Access Point Manager,
Performance Metrics, Web Socket Comms, App API, All running on ESP8266...
Even usable on ESP-01S --- Please check it out!
https://inqonthat.com/inqportal-the-three-line-promise/
https://InqOnThat.com/inqportal
