- Mon Oct 06, 2014 3:48 pm
#1336
johnyradio wrote:mamalala wrote:I would also guess that the '89 has a much smaller firmware basically just for setup and spitting out/accepting data, while the '66 has a rather large chunk of code handling all the IP protocol stuff and more.
Chris, how would that affect the ability of the '89 do stream high-bandwidth data?
thx!
Because a WiFi stick has little handling of IP packages, i would guess. I would think it is more of an "raw" device. The '66 however does the whole network stack itself. TCP/IP, DNS, etc. Since the stack runs on the small chip in this case, the effective throughput would naturally be lower than what you could get by just getting/sending raw data around with no protocol stack inbetween.
Plus, there may be a more aggressive power-saving scheme in the '66, since it is obviously aimed at IoT stuff and not data throughput.
Greetings,
Chris
