- Thu Jun 25, 2015 11:20 pm
#21709
deadmetaphor wrote:Actually, I have never kept it on long enough (since the flashing lights feels like something is definitely wrong) to see if it is heating up.
I check the connections and polarity again. They seem correct, unless my assumption about the jumpers on the power supply is wrong. But I do not have a multimeter to check the voltage being supplied.
I think this was a good catch (thanks!). I'll see how I can verify the voltage (may be, Arduino's ADC?)
I also wanted to add that the power supply LED goes off (see attached video) when I connect the CH_PD pin to Vcc, which I assume is because it is unable to supply or is getting short-circuited
Thanks for your attention guys!!
I have a couple of that same supply board and have been using them for weeks with ESP modules with no hassles. i am powering the supply with a 12v 2A plugpack supplied with external hard drives.
The only thing I find is that the 5v regulator gets a little warm if I setup the esp in AP mode, but nothing concerning.
The input voltage goes to the 5v reg and the output of that feeds the 3.3v reg so the 5v one will always be the warmer of the two if you are supplying more than 7v or so to the supply.
The jumpers are quite simply .. the 2 centre pins are both connected to the breadboard rails, so shorting to the outer on either then supplys either 5v or 3.3v.
The regs on mine are true AMS1117 .. these are rated for 15V max and output current of 1A.
specs at
http://www.advanced-monolithic.com/pdf/ds1117.pdfYou are better off using a switch mode supply for the plug pack than one with a transformer. the transformer ones are generally unregulated and also less current.
The green led on the supply is on the 5V regulator. It should not flicker at all unless you input supply cannot cope with the current demands or if you have a dodgy solder connection, dodgy switch (left side of switch is input, right side switches the 5v to the USB socket)
oh duh, supply schematic is easier than text .. heres one.
http://we.easyelectronics.ru/part/modul-pitaniya-ywrobot-breadboard-power-supply-mb-v2-mb102.htmlhint for finding circuits .. this one I googled 'ywrobot supply' and then look at google images..
