May be component error, have a look at this : http://rayshobby.net/?p=10241
Explore... Chat... Share...
GiovanniBauer wrote:anybody still having the "getting hot" issue?
I read on the following post that this is a resistor/LED issue. the current limiting resistor is too low. as I have four of this modules i can test if removing the resistor would solve the issue.
http://rayshobby.net/magic-smoke-seen-o ... 6-modules/
when im done testing ill get back here with the results!
