- Thu Dec 17, 2015 4:48 am
#36637
canibalimao wrote:I have bought a few of these converters when I was looking for a solution similar to yours:
http://www.aliexpress.com/item/5pcs-min ... eb201560_5
I wanted to power an Arduino Mini and a GPS receiver. It isn't a nice option for that. It didn't power the arduino and it got hot as hell. My fingers are still afraid of those PCBs!!!
I'm just waiting to have some free time to test those converters with an ESP.
I just bough 10 of them yesterday...
I will test with ESP-01 and tell you when I receive them.
If not sufficient, I may put two regulators for each ESP to obtain sufficient power supply... good or bad idea ?
Budro wrote:What kind of runtime are you hoping to get out of this? Between the 16 NeoPixels and the ESP8266, you're probably looking at just shy of an hour out of a 600mAh LiPo. If the weight constraint is because this is a flying (or other short term) application, you may be able to half your runtime (mAh), but double up your voltage for nominal weight difference.
All my battery powered ESP8266 projects are in the 5-6v range, so my experience with regulators won't be much help here unfortunately.
Yes, I actually have about an hour of runtime with 16 Neopixels and Arduino Pro Mini 3.3v.
And Yes, it's a flying object constraint
With your projects running 5-6v range, what kind of power supply and/or regulator do you use ?
Thanks
EDIT: I forgot to add that I also have two modules like these :
http://www.hobbyking.com/hobbyking/stor ... v_1A_.htmlThey boost the voltage from a 1S Lipo to 5v (have an over discharge protection too) and are cheap...
Why not use a simple 5v to 3.3v then for powering the ESP ?
Not very "efficient" but lightweight and maybe more "simple" to find cheap 5v --> 3.3v converters.
