- Tue Jan 13, 2015 4:42 am
#7178
Hi!
Thank you!
About the espmake, for some reason i thought it was a different version of make.
Perhaps if you write ESPMAKE.CMD in the article, i don't make that mistake. After all it was almost midnight, and my ESP8266 still not working, can not upload firmware.
I downloaded VS2013, but then when i tried to load your solution file, it died out complaining about missing project files. (they are missing, no doubt)
I was phased out at that moment, since i had VS2010 on the machione that complained about a 'neqwer format' of solution file.
I am assuming, since the old flash loader tool i have (exe), with some really old firmware i found, i can get the module to respond to AT commands, even if it's mostly 'error', or freezing, that my wiring is right. Running from external power-supply.
Thanks again!
