that the module may have some strange problem with long requests .
I have some http request that works in any "http consul" , but on the module, you always get syntax error before the request even sent!
So, its not that you dont get respond, its the module that is just not sending the request .
(chip is connected to the internet,and i run this commands in the Arduino monitor)
AT+CIPMUX=1
OKAT+CIPSTART=4,"TCP","api.parse.com",443
OK
Linked AT+CIPSEND=4,185
>GET https://api.parse.com/1/classes/DATA/TXcgRDCCRR\r\nX-Parse-Application-Id: y4eI4XmKNT5D6MVtC565xkEjBAkggTlTMt1erNKv\r\nX-Parse-REST-API-Key: KCf4NA2tvhBnIr33Vt8287m4AuhMVqvacsVeB4O0
wrong syntax
ERROR
SEND OKSo you get 3 things : wrong syntax , error , than send ok . wtf ???
It seems that there is some internal problem with it , that wouldn't let it send things to the net .
the request that works in any consul is :
GET /https://api.parse.com/1/classes/DATA/TXcgRDCCRR
X-Parse-REST-API-Key: KCf4NA2tvhBnIr33Vt8287m4AuhMVqvacsVeB4O0What can you do with this module if you cant connect to almost any website/server ???
