By duchere
#12593 Hi,
I'm experiencing difficulties to just power the wifi module.
I use a AMS1117 voltage regulator with two 10uF capacitors on each side. I also tried with 100uF on both sides or 100uF/1000uF The power source is a simple 9V battery and I also tried with a DC adapter. I also tried to put in series a 7805 and AMS1117.
I simply connect VCC and CH_PD to +3.3V and GND to GND. The blue led blinks for a second, and then turns off.
Normally, the blue link should remain turned on, right ?
Thanks.
