- Thu Sep 30, 2021 7:08 am
#92492
Thanks, confirms some of the things I've read or am figuring out by trial and error.
Although my code is written generically, I plan on its first use as the EEPROM replacement and setting it to use just the one (and same sector) as EEPROM. I have a similar round-robin methodology, however, I don't need the param/value pair scheme and I don't overwrite the old data. This saves that extra write on the flash. This, as of this morning is working. I'm still continuing the research on what happens when flash goes bad... (1) in general how it behaves and (2) how do Espressif's routines respond when it does.
As I was writing the O.P. I was debating about asking if anyone had any old ESP8266's with known bad flash portions and thought the logistics would be a headache getting them. Later had the epiphany to just make my own. I have a bunch of ESP-01s just gathering dust and hammering one didn't seem that big a deal...
I have the full sector (4096) erasing, writing, reading, validating... in hopes of finally getting some bad memory location errors and actually see what I'm looking for. AND then to develop and test handling such errors. I'm glad I did, I'm finding some other things out that I haven't seen on the Internet.
(1) The Abuser is nearing 600,000 cycles - While the Internet says 10,000 to 100,000 is a reasonable expectation.
(2) Its slowing down - When it first started, it was able to do 18 cycles/second, now its around 4 cycles/second. Although the Internet mentions slowing, it usually suggests that its more related to fragmentation, on-going re-ordering, but never about the actual process of writing getting slower. I'd really be interested in the actual science describing why a worn memory location take longer to write than fresh one.
