By extraclassik
#15799 Hi everybody,
I'm a noob :D and i'd like to know if this build :
http://www.instructables.com/id/Arduino ... /?ALLSTEPS
would be possible with just one esp8266 and no other arduino board attached ?
If yes how would you advise lowering the atx 5v stand by to 3.3v needed by esp8266 ?
I'd plan as well to add an esp8266 to each molex of the atx (minus the connector) then how would you advise the switch for the 5v and the 12v would this kind of other build be helpful ?
http://hackaday.com/2015/04/19/switch-m ... n-esp8266/
thanks in advance ;)
By MeNoGeek
#15870 Hey, welcome.
extraclassik wrote:http://www.instructables.com/id/Arduino-Controlled-ATX-Power-Supply/?ALLSTEPS
Of course, and the Esp can be even be programmed using the same language and IDE as an Arduino. Or you could program it with NodeMCU Lua which is even easier.
extraclassik wrote:lowering the atx 5v stand by to 3.3v needed by esp8266 ?
For example, with something like this:
http://www.ebay.com/itm/390861101908
You'll also need another curcuit (e.g. an optocoupler) to control the 'power on' line (the green wire) of the ATX supply.
extraclassik wrote:add an esp8266 to each molex of the atx (minus the connector) then how would you advise the switch for the 5v and the 12v would this kind of other build be helpful ?
I don't understand why you need more wifi modules. A single esp-12 might have enough GPIOs to switch all the 5V and 12V lines you need. But I don't think a board with a triac would be suitable for those DC voltages. Instead, you might want to use relay boards like this one:
http://www.ebay.com/itm/321655194634
Hope this helps.
