I wrote some code to send GET request to the server.
<html>
<head>
<title>ESP8266 LED Control</title>
</head>
<body>
<!-- in the <button> tags below the ID attribute is the value sent to the arduino -->
<button id="11" class="led">Toggle Pin 11</button> <!-- button for pin 11 -->
<button id="12" class="led">Toggle Pin 12</button> <!-- button for pin 12 -->
<button id="13" class="led">Toggle Pin 13</button> <!-- button for pin 13 -->
<script src="jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$(".led").click(function(){
var p = $(this).attr('id'); // get id value (i.e. pin13, pin12, or pin11)
// send HTTP GET request to the IP address with the parameter "pin" and value "p", then execute the function
$.get("http://192.168.0.101:80/", {pin:p}); // execute get request
</script>
</body>
</html>So a problem is occurring when one connection is opened and I send another GET request without closing the connection. The ESP is taking the second request as a different connection and after that it just hangs and works incorrectly until restarted.
The response of ESP looked like this, though the requests were from the same IP.
0,CONNECT
+IPD,0,374:GET /?pin=12 HTTP/1.1
Host: 192.168.0.101
Connection: keep-alive
Cache-Control: max-age=0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.130 Safari/537.36
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-US,en;q=0.8
1,CONNECT
+IPD,1,348:GET /?pin=11 HTTP/1.1
Host: 192.168.0.101
AT+CIPCLOSE=0
busy p...
AT+CIPCLOSE=1
busy p...
But this does not happen when I send data from some TCP Client software like Hercules, every data comes in the same connection, and everything works fine.
How do I get around this problem?
