If you need to work with a higher input voltage, you should consider using a switching regulator.
Better use something like AMS1117 rated to 1A.
martinayotte wrote:Also, the 78L33 is rated for 100mA, so since ESP8266 is taking more than that, it is normal that regulator is suffering, it will maybe even die later ...
right. esp8266 consumes almost sometimes 300ma peak on boot. 100ma not enough.
Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
