By Agustin Dal Lago
#31338 Hello guys,
This is my first post here so I apologize in advance if this is not the correct board or something like that.
I have spent two days trying to update OTA the firmware on the ESP_TEST board that is mentioned here: (http://tech.scargill.net/esp8266-test-board/) . It has a 2MB spi flash memory.
My code is a modified version of a sample code I got from the web and seems to be ok. The code is the following:
Code: Select all#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
#include "smartconfig.h"
#include "upgrade.h"
#include "os_type.h"
#include "mem.h"
#include "gpio.h"
#include "espconn.h"
static void ICACHE_FLASH_ATTR ota_finished_callback(void *arg)
   struct upgrade_server_info *update = arg;
   if (update->upgrade_flag == true)
      os_printf("[OTA]success; rebooting!\n");
      system_upgrade_reboot();
      os_printf("[OTA]failed!\n");
   os_free(update->pespconn);
   os_free(update->url);
   os_free(update);
#define pheadbuffer "Connection: keep-alive\r\n\
Cache-Control: no-cache\r\n\
\r\n"
static void ICACHE_FLASH_ATTR handleUpgrade(uint8_t serverVersion, const char *server_ip, uint16_t port, const char *path)
   const char* file;
   uint8_t userBin = system_upgrade_userbin_check();
   switch (userBin)
      case UPGRADE_FW_BIN1: file = "user2.2048.new.3.bin"; break;
      case UPGRADE_FW_BIN2: file = "user1.2048.new.3.bin"; break;
      default:
      os_printf("[OTA]Invalid userbin number!\n");
      return;
   uint16_t version=1;
   if (serverVersion <= version)
      os_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
      return;
   os_printf("[OTA]Upgrade available version: %d\n", serverVersion);
   struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
   update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
   os_memcpy(update->ip, server_ip, 4);
   update->port = port;
   os_printf("[OTA]Server "IPSTR":%d. Path: %s%s\n", IP2STR(update->ip), update->port, path, file);
   update->check_cb = ota_finished_callback;
   update->check_times = 10000;
   update->url = (uint8 *)os_zalloc(512);
   os_sprintf((char*)update->url,
   "GET %s%s HTTP/1.1\r\n"
   "Host: "IPSTR":%d\r\n"
   pheadbuffer,
   path, file, IP2STR(update->ip), update->port);
    if (system_upgrade_start(update) == false) {
      os_printf("[OTA]Could not start upgrade\n");
      os_free(update);
      os_printf("[OTA]Upgrading...\n");
void user_rf_pre_init(void)
void wifi_handle_event_cb(System_Event_t *evt)
    os_printf("event %x\n", evt->event);
    switch (evt->event) {
        case EVENT_STAMODE_CONNECTED:
            os_printf("connected to ssid %s, channel %d\n",
            evt->event_info.connected.ssid,
            evt->event_info.connected.channel);
            break;
        case EVENT_STAMODE_DISCONNECTED:
            os_printf("disconnected from ssid %s, reason %d\n",
            evt->event_info.disconnected.ssid,
            evt->event_info.disconnected.reason);
            break;
        case EVENT_STAMODE_AUTHMODE_CHANGE:
            os_printf("mode: %d -> %d\n",
            evt->event_info.auth_change.old_mode,
            evt->event_info.auth_change.new_mode);
            break;
        case EVENT_STAMODE_GOT_IP:
            os_printf("ip:" IPSTR ",mask:" IPSTR ",gw:" IPSTR,
            IP2STR(&evt->event_info.got_ip.ip),
            IP2STR(&evt->event_info.got_ip.mask),
            IP2STR(&evt->event_info.got_ip.gw));
            os_printf("\n");
               char ip[4] = {192, 168, 100, 15};
            os_printf("LLAMANDO!!\n");
            handleUpgrade(2, ip, 8000, "/upgrade/");
            break;
        case EVENT_SOFTAPMODE_STACONNECTED:
            os_printf("station: " MACSTR "join, AID = %d\n",
            MAC2STR(evt->event_info.sta_connected.mac),
            evt->event_info.sta_connected.aid);
            break;
        case EVENT_SOFTAPMODE_STADISCONNECTED:
            os_sprintf("station: " MACSTR "leave, AID = %d\n",
            MAC2STR(evt->event_info.sta_disconnected.mac),
            evt->event_info.sta_disconnected.aid);
            break;
        default:
        break;
user_set_station_config(void)
   char ssid[32] = "MYSSID";
   char password[64] = "MYPASS";
   struct station_config stationConf;
   stationConf.bssid_set = 0; //need not check MAC address of AP
   os_memcpy(&stationConf.ssid, ssid, 32);
   os_memcpy(&stationConf.password, password, 64);
   wifi_station_set_config(&stationConf);
void user_init(void)
    os_printf("ASDF\n");
   os_printf("HOLASDK version:%s\n\n", system_get_sdk_version());
    wifi_set_event_handler_cb(wifi_handle_event_cb);
   ///smartconfig_set_type(SC_TYPE_ESPTOUCH); //SC_TYPE_ESPTOUCH,SC_TYPE_AIRKISS,SC_TYPE_ESPTOUCH_AIRKISS
    wifi_set_opmode(STATION_MODE);
    //smartconfig_start(smartconfig_done);
   user_set_station_config();
I am using the 1.4.0 IOT SDK with bootloader 1.4(b1) and flashing to the following locations:
boot_v1.4(b1).bin to 0x00000
esp_init_data_default.bin to 0x1fc000
blank.bin to 0x1fe000
user1.2048.new.3.bin 0x01000
user2.2048.new.3.bin 0x81000
(NOTE> I tried flashing the 1MB flash version firmwares too, but same result...)
My log was:
Code: Select all ets Jan  8 2013,rst cause:1, boot mode:(3,2)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
SDK ver: 1.4.0 compiled @ Sep 18 2015 20:55:49
phy ver: 484, pp ver: 9.5
ASDF
HOLASDK version:1.4.0
mode : sta(18:fe:34:a1:32:8a)
add if0
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
connected with Belkin_Enhanced_Wireless_E53473, channel 1
dhcp client start...
event 0
connected to ssid Belkin_Enhanced_Wireless_E53473, channel 1
ip:192.168.100.39,mask:255.255.255.0,gw:192.168.100.1
event 3
LLAMANDO!!
[OTA]Upgrade available version: 2
[OTA]Server 192.168.100.15:8000. Path: /upgrade/user2.2048.new.3.bin
upgrade_connect
[OTA]Upgrading...
upgrade_connect_cb
GET /upgrade/user2.2048.new.3.bin HTTP/1.1
Host: 192.168.100.15:8000
HEAD /upgrade/user2.2048.new.3.bin HTTP/1.1
Connection: close
pusrdata = HTTP/1.0 200 OK
server do not support HEAD method now send GET message
pusrdata = Server: SimpleHTTP/0.6 Python/2.7.8
Date: Wed, 14 Oct 2015 16:11:33 GMT
Content-type: application/octet-stream
Content-Length: 218100
Last-Modified: Wed, 14 Oct 2015 16:07:56 GMT
Access-Control-Allow-Origin: *
sumlength = 218100
sec_block 54
......................................................upgrade_get_sum_disconcb
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
erase sector=134 ok
erase sector=135 ok
erase sector=136 ok
erase sector=137 ok
erase sector=138 ok
erase sector=139 ok
erase sector=140 ok
erase sector=141 ok
erase sector=142 ok
erase sector=143 ok
erase sector=144 ok
erase sector=145 ok
erase sector=146 ok
erase sector=147 ok
erase sector=148 ok
erase sector=149 ok
erase sector=150 ok
erase sector=151 ok
erase sector=152 ok
erase sector=153 ok
erase sector=154 ok
erase sector=155 ok
erase sector=156 ok
erase sector=157 ok
erase sector=158 ok
erase sector=159 ok
erase sector=160 ok
erase sector=161 ok
erase sector=162 ok
erase sector=163 ok
erase sector=164 ok
erase sector=165 ok
erase sector=166 ok
erase sector=167 ok
erase sector=168 ok
erase sector=169 ok
erase sector=170 ok
erase sector=171 ok
erase sector=172 ok
erase sector=173 ok
erase sector=174 ok
erase sector=175 ok
erase sector=176 ok
erase sector=177 ok
erase sector=178 ok
erase sector=179 ok
erase sector=180 ok
erase sector=181 ok
erase sector=182 ok
ALL=54 sectors erase ok!
upgrade_connect_cb
Connection: close
totallen = 17
totallen = 1477
totallen = 2937
totallen = 4397
totallen = 5857
totallen = 7317
totallen = 8777
totallen = 10237
totallen = 11697
totallen = 13157
totallen = 14617
totallen = 16077
totallen = 17537
totallen = 18997
totallen = 20457
totallen = 21917
totallen = 23377
totallen = 24837
totallen = 26297
totallen = 27757
totallen = 29217
totallen = 30677
totallen = 32137
totallen = 33597
totallen = 35057
totallen = 36517
totallen = 37977
totallen = 39437
totallen = 40897
totallen = 42357
totallen = 43817
totallen = 45277
totallen = 46737
totallen = 48197
totallen = 49657
totallen = 51117
totallen = 52577
totallen = 54037
totallen = 55497
totallen = 56957
totallen = 58417
totallen = 59877
totallen = 61337
totallen = 62797
totallen = 64257
totallen = 65717
totallen = 67177
totallen = 68637
totallen = 70097
totallen = 71557
totallen = 73017
totallen = 74477
totallen = 75937
totallen = 77397
totallen = 78857
totallen = 80317
totallen = 81777
totallen = 83237
totallen = 84697
totallen = 86157
totallen = 87617
totallen = 89077
totallen = 90537
totallen = 91997
totallen = 93457
totallen = 94917
totallen = 96377
totallen = 97837
totallen = 99297
totallen = 100757
totallen = 102217
totallen = 103677
totallen = 105137
totallen = 106597
totallen = 108057
totallen = 109517
totallen = 110977
totallen = 112437
totallen = 113897
totallen = 115357
totallen = 116817
totallen = 118277
totallen = 119737
totallen = 121197
totallen = 122657
totallen = 124117
totallen = 125577
totallen = 127037
totallen = 128497
totallen = 129957
totallen = 131417
totallen = 132877
totallen = 134337
totallen = 135797
totallen = 137257
totallen = 138717
totallen = 140177
totallen = 141637
totallen = 143097
totallen = 144557
totallen = 146017
totallen = 147477
totallen = 148937
totallen = 150397
totallen = 151857
totallen = 153317
totallen = 154777
totallen = 156237
totallen = 157697
totallen = 159157
totallen = 160617
totallen = 162077
totallen = 163537
totallen = 164997
totallen = 166457
totallen = 167917
totallen = 169377
totallen = 170837
totallen = 172297
totallen = 173757
totallen = 175217
totallen = 176677
totallen = 178137
totallen = 179597
totallen = 181057
totallen = 182517
totallen = 183977
totallen = 185437
totallen = 186897
totallen = 188357
totallen = 189817
totallen = 191277
totallen = 192737
totallen = 194197
totallen = 195657
totallen = 197117
totallen = 198577
totallen = 200037
totallen = 201497
totallen = 202957
totallen = 204417
totallen = 205877
totallen = 207337
totallen = 208797
totallen = 210257
totallen = 211717
totallen = 213177
totallen = 214637
totallen = 216097
totallen = 217557
totallen = 218335
pm open phy_2,type:2 0 0
upgrade_check
[OTA]failed!
I am using the ESP FLASH DOWNLOAD TOOL V1.2.
I thank you in advance for any help or input you could give on this. It has been really frustrating and don't know what else to do.
