i have embed a tiny dns in ESP8266 (using RTOS SDK)
but when runing the ESP8266, it was always put out something strange code to UART0
load 0x40100000, len 30140, room 16
tail 12
chksum 0x6d
ho 0 tail 12 room 4
load 0x3ffe8000, len 1148, room 12
tail 0
chksum 0x10
load 0x3ffe8480, len 784, room 8
tail 8
chksum 0x89
csum 0x89
劽諄MEM CHECK FAIL!!!my dns code is like below:
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include "Tinydns.h"
#include <lwip/sockets.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#define PORT 53
#define MSG_SIZE 256
void TinydnsTask(void *pvParameters)
struct sockaddr_in addr, server;
char *msg = (char *)malloc(MSG_SIZE);
// socket creation
int sd = socket(AF_INET, SOCK_DGRAM, 0);
if (sd < 0) {
//printf(stderr, "%s: cannot open socket \n", argv[0]);
//return 1;
asm("break 1,1");
printf("TinyDns open socket \n" );
// bind local server port
server.sin_family = AF_INET;
server.sin_addr.s_addr = htonl(INADDR_ANY);
server.sin_port = htons(PORT);
int rc = bind(sd, (struct sockaddr *) &server, sizeof(server));
if (rc < 0) {
//fprintf(stderr,"%s: cannot bind port number %d \n", argv[0],PORT);
//return 1;
asm("break 1,1");
printf("TinyDns Bind socket \n");
socklen_t len = sizeof(addr);
int flags = 0;
//int RxTimeout = 1000;
while (1) {
//int ret = setsockopt(sd, SOL_SOCKET, SO_RCVTIMEO, &RxTimeout, sizeof(int));
// receive message
int n = recvfrom(sd, msg, MSG_SIZE, flags, (struct sockaddr*)&addr, &len);
//int n = -1;
//vTaskDelay(1000);
if (n <= 0) {continue;}
printf("TinyDns recive msg : %d byte from socket \n",n);
// Same Id
msg[2] = 0x81; msg[3] = 0x80; // Change Opcode and flags
msg[6] = 0; msg[7] = 1; // One answer
msg[8] = 0; msg[9] = 0; // NSCOUNT
msg[10] = 0; msg[11] = 0; // ARCOUNT
// Keep request in message and add answer
msg[n++] = 0xC0; msg[n++] = 0x0C; // Offset to the domain name
msg[n++] = 0x00; msg[n++] = 0x01; // Type 1
msg[n++] = 0x00; msg[n++] = 0x01; // Class 1
msg[n++] = 0x00; msg[n++] = 0x00; msg[n++] = 0x00; msg[n++] = 0x3c; // TTL
msg[n++] = 0x00; msg[n++] = 0x04; // Size --> 4
msg[n++] = 0x12; msg[n++] = 0x34; msg[n++] = 0x56; msg[n++] = 0x78; // IP
// Send the answer
sendto(sd, msg, n, flags, (struct sockaddr *)&addr, len);
if (msg){
free(msg);
msg = NULL;
printf("free msg \n");
//return 0;
and i create a task in user_init() like that :
xTaskCreate(TinydnsTask, (signed char *)"Mdns", 256, NULL, 2, NULL);does anybody know what is wrong????
