First I flash firmware with nodemcu_integer_0.9.6-dev_20150704.bin .
After that I open ESPlorer select buadrate and click Open button for open PORT but program run ......... never stop . I conect Reset pin to ground. Then program show like this .
Got answer! AutoDetect firmware...
Can't autodetect firmware, because proper answer not received.I pase code and click Send to ESP but it show error like this
Uploading to ESP file ap.lua...Waiting answer from ESP - Timeout reached. Command aborted.I change program to use NodeMCU Studio program can select port only . when I click execute it show error.
COM Port TimeoutException Occurred, Please Check The Com Port And Restart this ApplicationHow to use NodeMCU with lua compiler ?
