I've just received my ESP8266-01 and I'd like to use it to monitor a water meter.
The water meter is quite simple : it has 2 pins (A & B) that acts like a switch : each 0->0,5 l, the "switch" is closed, each 0,5 -> 1 l, it is open.
I plan to connect pin A to the GND and pin B to the ESP-01 with a pull-up resistor connected to Vcc (so that the ESP-01 will either read LOW, or HIGH)
The main problem I'm facing concerns the boot of the ESP-01 : the GPIO #0 must not be LOW (connected to GND) otherwise it would start in 'program' mode so I can't connect the water meter on it as I can't know whether the water meter will be "open" or "closed" (so if the pin will be HIGH or LOW)
It seems that I can't either use the GPIO #2 as to boot in running mode, the ESP-01 need the GPIO #2 to be either unconnected, or HIGH.
I've tried Google but could not find any way. Can anybody explain me how to deal with this situation ?
Many thanks
Steph
