I have been struggling to make a UART Echo on UART0. I am using a NodeMCU Amica board. I input 1234567890 into the Transmit of Terminal and see 1VQ5ka95 on the Receive.
Other os_printf() string after the uart_init() works - So, I believe the bit-rate is not an issue. Can you please help me out here?
User Main function:
* Main User function
void ICACHE_FLASH_ATTR
user_init(void)
os_printf("SDK version:%s\n", system_get_sdk_version());
os_delay_us(1000);
/* Maintaining the same bit rate as SDK default. */
uart_init(BIT_RATE_74880,BIT_RATE_74880);
os_printf("UART bit rate set to 74880.\n" );
uart_init function:
uart_init(UartBautRate uart0_br, UartBautRate uart1_br)
/*this is a example to process uart data from task,please change the priority to fit your application task if exists*/
system_os_task(uart_recvTask, uart_recvTaskPrio, uart_recvTaskQueue,
uart_recvTaskQueueLen); //demo with a task to process the uart data
UartDev.baut_rate = uart0_br;
uart_config(UART0);
UartDev.baut_rate = uart1_br;
uart_config(UART1);
ETS_UART_INTR_ENABLE();
uart_recvTask function:
LOCAL void ICACHE_FLASH_ATTR ///////
uart_recvTask(os_event_t *events)
if (events->sig == 0)
#if UART_BUFF_EN
Uart_rx_buff_enq();
#else
uint8 fifo_len = (READ_PERI_REG(UART_STATUS(UART0)) >> UART_RXFIFO_CNT_S)
& UART_RXFIFO_CNT;
uint8 d_tmp = 0;
uint8 idx = 0;
for (idx = 0; idx < fifo_len; idx++)
d_tmp = READ_PERI_REG(UART_FIFO(UART0)) & 0xFF;
uart_tx_one_char(UART0, d_tmp);
WRITE_PERI_REG(UART_INT_CLR(UART0),
UART_RXFIFO_FULL_INT_CLR | UART_RXFIFO_TOUT_INT_CLR);
uart_rx_intr_enable(UART0);
#endif
else if (events->sig == 1)
#if UART_BUFF_EN
//already move uart buffer output to uart empty interrupt
//tx_start_uart_buffer(UART0);
#else
#endif
uart0_rx_intr_handler function:
LOCAL void
uart0_rx_intr_handler(void *para)
/* uart0 and uart1 intr combine togther, when interrupt occur, see reg 0x3ff20020, bit2, bit0 represents
* uart1 and uart0 respectively
uint8 RcvChar;
uint8 uart_no = UART0; //UartDev.buff_uart_no;
uint8 fifo_len = 0;
uint8 buf_idx = 0;
uint8 temp, cnt;
//RcvMsgBuff *pRxBuff = (RcvMsgBuff *)para;
/*ATTENTION:*/
/*IN NON-OS VERSION SDK, DO NOT USE "ICACHE_FLASH_ATTR" FUNCTIONS IN THE WHOLE HANDLER PROCESS*/
/*ALL THE FUNCTIONS CALLED IN INTERRUPT HANDLER MUST BE DECLARED IN RAM */
/*IF NOT , POST AN EVENT AND PROCESS IN SYSTEM TASK */
if (UART_FRM_ERR_INT_ST
== (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_FRM_ERR_INT_ST))
DBG1("FRM_ERR\r\n");
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_FRM_ERR_INT_CLR);
else if (UART_RXFIFO_FULL_INT_ST
== (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_FULL_INT_ST))
DBG("f");
uart_rx_intr_disable(UART0);
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_FULL_INT_CLR);
system_os_post(uart_recvTaskPrio, 0, 0);
else if (UART_RXFIFO_TOUT_INT_ST
== (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_TOUT_INT_ST))
DBG("t");
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_TOUT_INT_CLR);
else if (UART_TXFIFO_EMPTY_INT_ST
== (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_TXFIFO_EMPTY_INT_ST))
DBG("e");
/* to output uart data from uart buffer directly in empty interrupt handler*/
/*instead of processing in system event, in order not to wait for current task/function to quit */
/*ATTENTION:*/
CLEAR_PERI_REG_MASK(UART_INT_ENA(UART0), UART_TXFIFO_EMPTY_INT_ENA);
#if UART_BUFF_EN
#endif
//system_os_post(uart_recvTaskPrio, 1, 0);
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_TXFIFO_EMPTY_INT_CLR);
else if (UART_RXFIFO_OVF_INT_ST
== (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_OVF_INT_ST))
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_RXFIFO_OVF_INT_CLR);
DBG1("RX OVF!!\r\n");
