I'm a new guy in esp8266 programming and hope to community support in my project.
The general idea is I have a uart link between two uC (RX pin -> TX pin) This link should be extended via WiFi.
Now I have two esp8266 modules.
1. The first esp8266 is connected to source uC (uC RX pin -> esp8622 TX pin) This esp works as AP and flashed by esp-link firmware. As I see this works as expected. It takes data from uC RX pin and transfers via WiFi. It is possible to telnet 192.168.4.1 23 port and see bytes coming.
2. The question is about 2nd esp8266. This one should connects to 1st esp, receives data and put to his RX pin. Then I'll connect destination uC and links will work as designed.
Please advice what firmware I could use for #2?
Any ides would be welcome
Thanks!
