last week my ordered ESP8266 devices finally arrived and I started to work with it today. My plan was to connect the ESP to a switch and connect to a server, when the switch is activated. But first of all I have a huge problem connecting the ESP to my Win 10 desktop PC. I'm a fairly new to serial communication between devices, please be patient.
I own a 3,3V USB to serial adapter, with FTDI FT232RL chip on it, to connect to the ESP8266. At first I connected them like in the link below. But I didn't get any results ( using neither putty nor termite worked)
http://www.instructables.com/id/Blink-f ... mware-SDK/
Looking for solutions to my problem I found out, that the power supply from the adapter could be to low, so I used a 600mA power supply and a voltage regulator to supply the ESP with sufficient power. The voltage supply is constantly at 3.3V and red LED on. Now I tried again and got a line of signs in the terminal and the blue LED temporarly flashes. So I changed the baud rate to every possible value, but nothing happend. When I disconnect ch_pd vom VCC this stops and the blue LED is constantly on. But I don't get any answers on AT commands.
What I also did: Testing different ESPs, Connecting GPIO 0 to GND/VCC and checked the TX/RX Voltage of the adapter (3,3V).
Can anybody help me connecting the ESP8266 to my PC?
Many Thanks in advance!
