By col805
#41258 Hi,After reading the data on the ESP8266 module it appears that it has all the required capability to handle the WiFi coms and has some onboard capacity to do some manipulation of in-coming data. Can anyone tell me if it could be used for the following application. I have a tank about 50 feet from the house where the computer is. The tank has an electronic level device with a voltage output. Can I put the voltage into the D/A input of the ESP8266 module modify the signal (zero & scale) and have it available to be read by the computer when desired without needing an extra mico. To interface with it?
Any help is appreciated.
Col805
