i have ESP8266-01 and i flashed it with Node MCU firmware
and i have problems with writing lua code to make the esp work as client and server at the same time , any idea how to do that please ?
Explore... Chat... Share...
technochatter wrote:Here is an example, I hope it helps:
http://randomnerdtutorials.com/how-to-m ... 8266-talk/
(By the way I am not promoting the above site, too much pop up ads- personal opinion)
You can use the arduino IDE too if you are not comfortable with Node MCU.
