- Tue Mar 22, 2016 12:14 pm
#43808
Hey welcome
First make sure that you installed the last version of Arduino and
Start Arduino and open Preferences window.
Enter
http://arduino.esp8266.com/stable/packa ... index.json into Additional Board Manager URLs field. You can add multiple URLs, separating them with commas.
Open Boards Manager from Tools > Board menu and install esp8266 platform (and don't forget to select your ESP8266 board from Tools > Board menu after installation).
This is the example that you need:
It starts an AP with the name: ESPap
and the password thereisnospoon
When someone connects to the IP of the acces point (192.168.4.1), they will get the website within the handleRoot() function.
You are connected
[s]If you want to respond to every ip adress or domain name than you need some tweaking in the DNS Library
viewtopic.php?f=32&t=3618 [/s]
Source:
https://github.com/esp8266/Arduino/blob ... sPoint.inoCode: Select all#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "ESPap";
const char *password = "thereisnospoon";
ESP8266WebServer server(80);
/* Just a little test message. Go to http://192.168.4.1 in a web browser
* connected to this access point to see it.
void handleRoot() {
server.send(200, "text/html", "<h1>You are connected</h1>");
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.handleClient();
} This is the code if you want to respond to every request, doesn't matter if the user tries to reach google.com or facebook.com he will always get your page...
#include <DNSServer.h>
const byte DNS_PORT = 53;
IPAddress apIP(192, 168, 1, 1);
DNSServer dnsServer;
ESP8266WebServer webServer(80);
String responseHTML = ""
"<!DOCTYPE html><html><head><title>CaptivePortal</title></head><body>"
"<h1>Hello World!</h1><p>This is a captive portal example. All requests will "
"be redirected here.</p></body></html>";
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP("DNSServer CaptivePortal example");
// if DNSServer is started with "*" for domain name, it will reply with
// provided IP to all DNS request
dnsServer.start(DNS_PORT, "*", apIP);
// replay to all requests with same HTML
webServer.onNotFound([]() {
webServer.send(200, "text/html", responseHTML);
webServer.begin();
dnsServer.processNextRequest();
webServer.handleClient();
