http://randomnerdtutorials.com/door-sta ... e-esp8266/
I am sure the code could be modified but is beyond my skills. thanks in advance
Explore... Chat... Share...
Created by Rui Santos
All the resources for this project:
Based on some ESP8266 code examples
const char* ssid = "YOUR_SSID";
const char* password = "YOUR_PASSWORD";
const char* host = "maker.ifttt.com";
const char* apiKey = "YOUR_IFTTT_API_KEY";
int pin1 = 2;
int pin2 = 3;
volatile int state1 = false;
volatile int flag1 = false;
const char* door_state1 = "closed";
volatile int state2 = false;
volatile int flag2 = false;
const char* door_state2 = "closed";
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
const long interval = 3000;
void changeDoorStatus1() {
unsigned long currentMillis1 = millis();
if(currentMillis1 - previousMillis1 >= interval) {
previousMillis1 = currentMillis1;
state1 = !state1;
if(state1) {
door_state1 = "opened";
else{
flag1 = true;
Serial.println(state1);
Serial.println(door_state1);
void changeDoorStatus2() {
unsigned long currentMillis2 = millis();
if(currentMillis2 - previousMillis2 >= interval) {
previousMillis2 = currentMillis2;
state2 = !state2;
if(state2) {
door_state2 = "opened";
else{
flag2 = true;
Serial.println(state2);
Serial.println(door_state2);
delay(100);
Serial.println("Preparing the Door Status Monitor project...");
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
attachInterrupt(digitalPinToInterrupt(pin1), changeDoorStatus1, CHANGE);
attachInterrupt(digitalPinToInterrupt(pin2), changeDoorStatus2, CHANGE);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
if(flag1){
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
String url = "/trigger/door_status1/with/key/";
url += apiKey;
Serial.println(url);
client.print(String("POST ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Content-Type: application/x-www-form-urlencoded\r\n" +
"Content-Length: 13\r\n\r\n" +
"value1=" + door_state1 + "\r\n");
flag1 = false;
delay(10);
if(flag2){
WiFiClient client;
return;
String url = "/trigger/door_status2/with/key/";
url += apiKey;
"value1=" + door_state2 + "\r\n");
flag2 = false;
delay(10);
}It takes about 20-25 seconds for home assistant c[…]
