It connects and all looks good, then I open putty and try to connect to port 8888 and IP that the serial window returns, and I get a connection refused.
Yes my PC and the ESP8266 are on the same router, I am 192.168.1.20 and the esp is 192.168.1.22
RichardS
#include <WiFiUDP.h>
// wifi connection variables
const char* ssid = "***";
const char* password = "***";
boolean wifiConnected = false;
// UDP variables
unsigned int localPort = 8888;
WiFiUDP UDP;
boolean udpConnected = false;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
delay(2000);
// Initialise Serial connection
Serial.begin(9600);
// Initialise wifi connection
wifiConnected = connectWifi();
// only proceed if wifi connection successful
if (wifiConnected) {
udpConnected = connectUDP();
if (udpConnected) {
// initialise pins
// check if the WiFi and UDP connections were successful
if (udpConnected) {
// if there’s data available, read a packet
int packetSize = UDP.parsePacket();
if (packetSize)
Serial.println("");
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = UDP.remoteIP();
for (int i = 0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print(".");
Serial.print(", port ");
Serial.println(UDP.remotePort());
// read the packet into packetBufffer
UDP.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents: ");
int value = packetBuffer[0] * 256 + packetBuffer[1];
Serial.println(value);
// send a reply, to the IP address and port that sent us the packet we received
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
UDP.write(ReplyBuffer);
UDP.endPacket();
// turn LED on or off depending on value recieved
delay(10);
// connect to UDP – returns true if successful or false if not
boolean connectUDP() {
boolean state = false;
Serial.println("");
Serial.println("Connecting to UDP");
if (UDP.begin(localPort) == 1) {
Serial.println("Connection successful");
state = true;
else {
Serial.println("Connection failed");
return state;
// connect to wifi – returns true if successful or false if not
boolean connectWifi() {
boolean state = true;
int i = 0;
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting");
Serial.print(".");
if (i > 10) {
state = false;
break;
i++;
if (state) {
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
else {
Serial.println("");
Serial.println("Connection failed.");
return state;
}https://epartsconnect.com
Live realtime stock market prediction website. https://www.stocksignalslive.com my latest creation. Uses AI and machine learning.
New site featuring ESP8266 and ESP32 projects. tutorials, and news.
http://EverythingESP.com
ESP8266.com Founder and Administrator
The Mind Factory (get more from your 3D printer)
Home of the ESP8266, ESP8285, and ESP32 microcontrollers....
