By sparkz19
#45425 Sending data to the server(thingspeak.com/184.106.153.14) with AT commands on serial monitor works fine but whenever i upload the sketch ,the following always return false if(Serial.find( ">" ) ). I am not sure if AT+CIPSEND is not working correctly or what. I am using Arduino with ESP8266. Any help will be appreciated.Thanks you in advance. Here is my code.
Code: Select all#include <SoftwareSerial.h>
  SoftwareSerial softSerial(2, 3); // RX, TX
  #define SSID "myssid"
  #define PASS "Mypass"
  #define IP "184.106.153.149" // ThingSpeak
  void setup()
   uint32_t baud = 9600;
   Serial.begin(baud);
   softSerial.begin(baud);
   connectWiFi();
   void loop()
    updateTS();
    void updateTS()
    String cmd = "AT+CIPSTART=\"TCP\",\"";// Setup TCP connection
    cmd += IP;
    cmd += "\",80";
    sendDebug(cmd);
    delay(2000);
    String url = "GET /update?key=P55Z0BDASNQBFQKT&field1=15&field2=25\r\n\r\n"; //hard code value 15 and 25
    String stringLength="AT+CIPSEND=";
    stringLength +=String(url.length( ));
    Serial.println(stringLength);
    //delay(10000); I even tried to delay for few seconds
   //Here is where it fails,it jumps to closing the connection
     softSerial.print(">");
     softSerial.print(cmds);
     Serial.print(cmds);
     sendDebug( "AT+CIPCLOSE" );//close TCP connection
   void sendDebug(String cmd)
      softSerial.print("SEND: ");
      softSerial.println(cmd);
     boolean connectWiFi()
      Serial.println("AT+CWMODE=1");
      delay(2000);
      String cmd="AT+CWJAP=\""; // Join accespoint
      cmd+=SSID;
      cmd+="\",\"";
      cmd+=PASS;
      cmd+="\"";
      sendDebug(cmd);
      delay(5000);
      if(Serial.find("OK"))
       softSerial.println("RECEIVED: OK");
       return true;
       softSerial.println("RECEIVED: Error");
       return false;
