By enpolig
#24694 Hello, guys
I have a problem: my esp8266 cannot send data to narodmon.ru, but sometimes it does
Don't know why it works so weird
Code: Select all#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#include <SFE_BMP180.h>
#include <ESP8266.h> // ITEADLIB
#include <SoftwareSerial.h>
#define SSID        "AP_NAME"
#define PASSWORD    "AP_PASS"
#define HOST_NAME   "94.19.113.221"
#define HOST_PORT   (8283)
#define PRESSURE_MEASUREMENT_INTERVAL 2000
#define LED 13 // LED on D13
#define CHANNEL 3 // oregon channel
LiquidCrystal_I2C lcd(0x27, 16, 2);
SFE_BMP180 pressure;
char mac[] = "0123456789AB";
SoftwareSerial mySerial(8, 9); /* RX:D9, TX:D8 */
ESP8266 wifi(mySerial);
boolean got_humidity, got_pressure, got_temperature = false; // logic variable to test recieving data
// temperature, humidity and battery
float t[2];
byte h[2];
byte b[2];
double temp;
byte hum;
double pres;
char temp_ch[8];
char pres_ch[8];
unsigned long dispNow = 0;
// Oregon V2 decoder added - Dominique Pierre
// New code to decode OOK signals from weather sensors, etc.
// 2010-04-11 <jcw@equi4.com> http://opensource.org/licenses/mit-license.php
// $Id: ookDecoder.pde 5331 2010-04-17 10:45:17Z jcw $
class DecodeOOK {
  protected:
    byte total_bits, bits, flip, state, pos, data[25];
    virtual char decode (word width) = 0;
  public:
    enum {
      UNKNOWN, T0, T1, T2, T3, OK, DONE
    DecodeOOK () {
      resetDecoder();
    bool nextPulse (word width) {
      if (state != DONE)
        switch (decode(width)) {
          case -1:
            resetDecoder();
            break;
          case 1:
            done();
            break;
      return isDone();
    bool isDone () const {
      return state == DONE;
    const byte* getData (byte& count) const {
      count = pos;
      return data;
    void resetDecoder () {
      total_bits = bits = pos = flip = 0;
      state = UNKNOWN;
    // add one bit to the packet data buffer
    virtual void gotBit (char value) {
      total_bits++;
      byte *ptr = data + pos;
      *ptr = (*ptr >> 1) | (value << 7);
      if (++bits >= 8) {
        bits = 0;
        if (++pos >= sizeof data) {
          resetDecoder();
          return;
      state = OK;
    // store a bit using Manchester encoding
    void manchester (char value) {
      flip ^= value; // manchester code, long pulse flips the bit
      gotBit(flip);
    // move bits to the front so that all the bits are aligned to the end
    void alignTail (byte max = 0) {
      // align bits
      if (bits != 0) {
        data[pos] >>= 8 - bits;
        for (byte i = 0; i < pos; ++i)
          data[i] = (data[i] >> bits) | (data[i + 1] << (8 - bits));
        bits = 0;
      // optionally shift bytes down if there are too many of 'em
      if (max > 0 && pos > max) {
        byte n = pos - max;
        pos = max;
          data[i] = data[i + n];
    void reverseBits () {
      for (byte i = 0; i < pos; ++i) {
        byte b = data[i];
        for (byte j = 0; j < 8; ++j) {
          data[i] = (data[i] << 1) | (b & 1);
          b >>= 1;
    void reverseNibbles () {
        data[i] = (data[i] << 4) | (data[i] >> 4);
    void done () {
      while (bits)
        gotBit(0); // padding
      state = DONE;
// 433 MHz decoders
class OregonDecoderV2 :
  public DecodeOOK {
  public:
    OregonDecoderV2() {
      if (!(total_bits & 0x01))
        data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00);
      total_bits++;
      pos = total_bits >> 4;
      if (pos >= sizeof data) {
        resetDecoder();
        return;
      state = OK;
    virtual char decode (word width) {
      if (200 <= width && width < 1200) {
        byte w = width >= 700;
        switch (state) {
          case UNKNOWN:
            if (w != 0) {
              // Long pulse
              ++flip;
            else if (32 <= flip) {
              // Short pulse, start bit
              flip = 0;
              state = T0;
            else {
              // Reset decoder
              return -1;
            break;
          case OK:
            if (w == 0) {
              // Short pulse
              state = T0;
            else {
              // Long pulse
              manchester(1);
            break;
          case T0:
            if (w == 0) {
              // Second short pulse
              manchester(0);
            else {
              // Reset decoder
              return -1;
            break;
      else {
        return -1;
      return total_bits == 160 ? 1 : 0;
OregonDecoderV2 orscV2;
volatile word pulse;
void ext_int_1(void) {
  static word last;
  pulse = micros() - last;
  last += pulse;
long lastSend;
void reportLCD (const char* s, class DecodeOOK& decoder) {
  byte pos;
  const byte* data = decoder.getData(pos);
  if (data[0] == 0x1A && data[1] == 0x2D)
    if (channel(data) == CHANNEL) { // Get data from sensor which channel is CHANNEL
      temp = temperature(data);
      got_temperature = true;
      hum = humidity(data);
      got_humidity = true;
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print("Temp:");
      lcd.setCursor(5, 0);
      lcd.print(temperature(data));
      lcd.setCursor(9, 0);
      lcd.print("'C");
      lcd.setCursor(0, 1);
      lcd.print("Hum:");         // Will be smth as this |
      lcd.setCursor(4, 1);            //  _______________V_
      lcd.print(humidity(data));      // /________________/|
      lcd.setCursor(6, 1);            // |Temp:9.80'C_____||
      lcd.print("%");                 // |Hum:50%_752.22mm|/
  decoder.resetDecoder();
long time;
void setup () {
  Serial.begin(9600); // init esp8266
  Serial.print("setup begin\r\n");
  Serial.print("FW Version:");
  Serial.println(wifi.getVersion().c_str());
  if (wifi.setOprToStationSoftAP()) {
    Serial.print("to station + softap ok\r\n");
  } else {
    Serial.print("to station + softap err\r\n");
  if (wifi.joinAP(SSID, PASSWORD)) {
    Serial.print("Join AP success\r\n");
    Serial.print("IP:");
    Serial.println( wifi.getLocalIP().c_str());
  } else {
    Serial.print("Join AP failure\r\n");
  if (wifi.disableMUX()) {
    Serial.print("single ok\r\n");
  } else {
    Serial.print("single err\r\n");
  Serial.print("setup end\r\n");
  pressure.begin();
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.print("Loading...");
  lcd.createChar(0, percent);
  pinMode(2, INPUT);  // There is 433mhz reciever
  digitalWrite(2, 1); // Pull-up resistor
  attachInterrupt(0, ext_int_1, CHANGE); // interrupt
long previousTime; // Timing for pressure sensor
void loop () {
  long currentTime = millis(); // Current time
  char status; // All clear
  double P, T;
  if (currentTime - previousTime > PRESSURE_MEASUREMENT_INTERVAL) { // Data on lcd updates once every PRESSURE_MEASUREMENT_INTERVAL
    previousTime = currentTime; // Recieving bmp180 data and show it
    status = pressure.startTemperature(); // Впрочем, ничего особенного
    if (status != 0) {
      delay(status);
      status = pressure.getTemperature(T);
      if (status != 0) {
        status = pressure.startPressure(3);
        if (status != 0) {
          delay(status);
          status = pressure.getPressure(P, T);
          if (status != 0) {
            lcd.setCursor(8, 1);
            lcd.print(P * 0.75);
            pres = P * 0.75;
            got_pressure = true;
            lcd.setCursor(14, 1);
            lcd.print("mm");
  noInterrupts();
  word p = pulse;
  pulse = 0;
  interrupts();
  if (p != 0) {
    if (orscV2.nextPulse(p)) {
      reportLCD("OSV2", orscV2);
      Serial.print("Temp:");
      Serial.println(temp);
      Serial.print("Humidity:");
      Serial.println(hum);
      Serial.print("Pressure:");
      Serial.println(pres);
      Serial.print(got_temperature);
      Serial.print(got_humidity);
      Serial.println(got_pressure);
      digitalWrite(LED, HIGH);
  // If 10 minutes gone and recieved hunidity/temperature/pressure
  if (millis() - lastSend > 60000 && got_humidity && got_temperature && got_pressure) {
    uint8_t buffer[128] = {0};
    if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
      Serial.print("create tcp ok\r\n"); // Sometimes
    } else {
      Serial.print("create tcp err\r\n"); // Almost everytime
    char hello[128];
    dtostrf(temp,3,1,temp_ch);
    dtostrf(pres,3,1,pres_ch);
    sprintf(hello, "\#%s\r\n\#T1#%s\r\n#H1\#%d\r\n\#P1\#%s\r\n\#\#", mac, temp_ch, hum, pres_ch);
    Serial.println("Sending:");
    Serial.println(hello);
    wifi.send((const uint8_t*)hello, strlen(hello));// That's all
    // So much weird... Wow
    uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
    if (len > 0) {
      Serial.print("Received:[");
      for (uint32_t i = 0; i < len; i++) {
        Serial.print((char)buffer[i]);
      Serial.print("]\r\n");
    if (wifi.releaseTCP()) {
      Serial.print("release tcp ok\r\n");
    } else {
      Serial.print("release tcp err\r\n");
    lastSend = millis();
float temperature(const byte* data)
  int sign = (data[6] & 0x8) ? -1 : 1;
  float temp = ((data[5] & 0xF0) >> 4) * 10 + (data[5] & 0xF) + (float)(((data[4] & 0xF0) >> 4) / 10.0);
  return sign * temp;
byte humidity(const byte* data)
  return (data[7] & 0xF) * 10 + ((data[6] & 0xF0) >> 4);
// Ne retourne qu'un apercu de l'etat de la baterie : 10 = faible
byte battery(const byte* data)
  return (data[4] & 0x4) ? 10 : 90;
byte channel(const byte* data)
  byte channel;
  switch (data[2])
    case 0x10:
      channel = 1;
      break;
    case 0x20:
      channel = 2;
      break;
    case 0x40:
      channel = 3;
      break;
  return channel;
void printValues() {
  char buf[16];
  char tbuf[6];
  char templ[] = {' ', '%', 's', char(223), 'C', ' ', '%', '3', 'd', '%', '%', ' ', ' ', ' ', '\0'};
  for (int i = 0; i < 2; i++) {
    if (b[i] > 50) {
      templ[13] = char(219);
    else {
      templ[13] = char(161);
    dtostrf(t[i], 5, 1, tbuf);
    sprintf(buf, templ, tbuf, h[i]);
    Serial.println(buf);
Watch 355 - 390 line
Output: setup begin
FW Version:0018000902
Join AP success
IP:192.168.4.1
192.168.1.2
single ok
setup end
25.60
44
744.59
111
create tcp err
Sending:
#0123456789
#T1#25.6
#H1#44
#P1#744.6
release tcp err
Help please
