By thedroid
#24752 Is it possible / ok to change the port that WiFiServer listens on at runtime?
See test case below (not compile tested).
Thx.
WiFiServer server(9001);
boolean testchange = true;
void setup (void)
   server.begin()
void loop  (void) {
  if (testchange == true)
     # Does this work, is it OK to do?
      server = WiFiServer(8001);
     # Do we need to call begin again?
      sever.begin()
    testchange = false;
## Do stuff with server here.
By kolban
#24772 Howdy there,
Looking at the source file called WiFiServer.cpp, I seem to find that when we create a new instance of the WiFiServer class and call its begin() method, it starts the server running. However, I could find no corresponding method or mechanism to stop it running. So, if you create a second instance of a WiFiServer on a different port ... that is ok, but the original port is still an active listener.
Neil
