And typing Ctrl-M/Ctrl-J in an AT shell is almost impossible, due to typing speed, it need to be done from from your Arduino sketch, or from PC using a python script or such...
I hate AT firmware !
Explore... Chat... Share...
I had to change line 42 in SoftwareSerial.h to
#define _SS_MAX_RX_BUFF 512
Also :
i changed line 67 and 68 in SoftwareSerial.h to
static volatile uint16_t _receive_buffer_tail;
static volatile uint16_t _receive_buffer_head;
and changed line 137 and 138 in SoftwareSerial.cpp to
volatile uint16_t SoftwareSerial::_receive_buffer_tail = 0;
volatile uint16_t SoftwareSerial::_receive_buffer_head = 0;
