I can connect to the AP and also connect to the webserver after logging in to the AP. But ít only shows a empty table. If I look at the serial monitor the sensor outputs all data correctly.
Have I done anything wrong modifying the code?
// ESP8266 Pins
// 4(SDA) --- AMG8833 SDA
// 5(SCL) --- AMG8833 SCL
// 13 --- LED (Anode) via 100ohm
#include <pgmspace.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WebSocketsServer.h>
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
Adafruit_AMG88xx amg;
const char* ssid = "Jacksson";
const char* password = "mandelvatten";
const int pin_led = 13;
ESP8266WebServer server(80);
WebSocketsServer webSocket(81);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
switch (type) {
case WStype_DISCONNECTED:
Serial.printf("[%u] Disconnected!\n", num);
break;
case WStype_CONNECTED:
IPAddress ip = webSocket.remoteIP(num);
Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
break;
void toggle() {
static bool last_led = false;
last_led = !last_led;
digitalWrite(pin_led, last_led);
void handleRoot() {
auto ip = WiFi.localIP();
String ip_str = String(ip[0]) + "." + ip[1] + "." + ip[2] + "." + ip[3];
server.send(200, "text/html", String(ws_html_1()) + ip_str + ws_html_2());
// server.send(200, "text/html", "<h1>You are connected</h1>");
void handleNotFound() {
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i = 0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void WiFiEvent(WiFiEvent_t event) {
switch(event) {
case WIFI_EVENT_STAMODE_DISCONNECTED:
digitalWrite(pin_led, LOW);
Serial.println("WiFi lost connection: reconnecting...");
WiFi.begin();
break;
case WIFI_EVENT_STAMODE_CONNECTED:
Serial.println(ssid);
break;
case WIFI_EVENT_STAMODE_GOT_IP:
digitalWrite(pin_led, HIGH);
Serial.print("IP address: ");
if (MDNS.begin("esp8266-amg8833")) {
Serial.println("MDNS responder started");
enableOTA();
break;
void enableOTA() {
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
// ArduinoOTA.setHostname("myesp8266");
// No authentication by default
// ArduinoOTA.setPassword((const char *)"123");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
void setup(void) {
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.on("/current", [](){
String str;
server.send(200, "text/plain", get_current_values_str(str));
server.onNotFound(handleNotFound);
server.begin();
webSocket.begin();
webSocket.onEvent(webSocketEvent);
amg.begin(0x69);
delay(100); // let sensor boot up
void loop(void) {
ArduinoOTA.handle();
server.handleClient();
webSocket.loop();
static unsigned long last_read_ms = millis();
unsigned long now = millis();
if (now - last_read_ms > 100) {
last_read_ms += 100;
String str;
get_current_values_str(str);
Serial.println(str);
webSocket.broadcastTXT(str);
String& get_current_values_str(String& ret)
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
amg.readPixels(pixels);
ret = "[";
for(int i = 0; i < AMG88xx_PIXEL_ARRAY_SIZE; i++) {
if( i % 8 == 0 ) ret += "\r\n";
ret += pixels[i];
if (i != AMG88xx_PIXEL_ARRAY_SIZE - 1) ret += ", ";
ret += "\r\n]\r\n";
return ret;
const __FlashStringHelper* ws_html_1() {
return F("<!DOCTYPE html>\n"
"<html>\n"
"<head>\n"
"<title>thermo</title>\n"
"<style>\n"
"body {\n"
" background-color: #667;\n"
"}\n"
"table#tbl td {\n"
" width: 64px;\n"
" height: 64px;\n"
" border: solid 1px grey;\n"
" text-align: center;\n"
"}\n"
"</style>\n"
"</head>\n"
"<body>\n"
"<h1>Exjobbsgrejs</h1>"
"<table border id=\"tbl\"></table>\n"
"<script>\n"
"function bgcolor(t) {\n"
" if (t < 0) t = 0;\n"
" if (t > 30) t = 30;\n"
" return \"hsl(\" + (360 - t * 12) + \", 100%, 80%)\";\n"
"}\n"
"\n"
"var t = document.getElementById('tbl');\n"
"var tds = [];\n"
"for (var i = 0; i < 8; i++) {\n"
" var tr = document.createElement('tr');\n"
" for (var j = 0; j < 8; j++) {\n"
" var td = tds[i*8 + 7 - j] = document.createElement('td');\n"
" tr.appendChild(td);\n"
" }\n"
" t.appendChild(tr);\n"
"}\n"
"var connection = new WebSocket('ws://");
const __FlashStringHelper* ws_html_2() {
return F(":81/');\n"
"connection.onmessage = function(e) {\n"
" const data = JSON.parse(e.data);\n"
" for (var i = 0; i < 64; i++) {\n"
" tds[i].innerHTML = data[i].toFixed(2);\n"
" tds[i].style.backgroundColor = bgcolor(data[i]);\n"
" }\n"
"};\n"
"</script>\n"
"</body>\n"
"</html>\n");
